Lt1..Coil?
There are 2 current setups that eliminate the LT1 computer, but one still uses the Optical sensor, the other just uses the Opti unit housing. Both use reluctor wheels to do part of the job.
So while that motor is damn nice, it's not near as involved as you think
It could very well just be a repainted mostly stock LT1 with LTCC mod and LT4 composite valve covers with the chromed center inserts. Here's the 2 threads. Both are still ongoing projects, but are also both in working stages.
Cheapest version, but a bit further behind in dev due to working on computer tune.
https://ls1tech.com/forums/lt1-lt4-m...tml?highlight=
Been in the works the longest and has better support due to being developed by a company (even if it's only a handful of people heh). Quite a long thread, as I posted it long ago.
https://ls1tech.com/forums/lt1-lt4-m...s-ls1-pcm.html
