What heads???
Old Feb 24, 2009 | 04:00 PM
BlackTA96's Avatar
Default What heads???
been shoppin around for some different heads.
What would yall recommend?
The afr 227's look pretty sweet.
Old Feb 24, 2009 | 04:22 PM
$O$OE's Avatar
Ai 200cc heads
Old Feb 24, 2009 | 04:25 PM
$O$OE's Avatar
https://ls1tech.com/forums/lt1-lt4-m...na-9s-n2o.html
they work wonders, they work nice on this stock short block, imagine more cubes woking with these heads!
Old Feb 24, 2009 | 04:27 PM
speed_demon24's Avatar
You are gonna need to post alot more about your setup/goals/budget if you want people to reccomend heads. There is no one size fits all as far as heads go.
Old Feb 24, 2009 | 04:41 PM
chavez885's Avatar
LT4 heads / Cam
If you want to go slow.
Old Feb 24, 2009 | 04:43 PM
ulakovic22's Avatar
Are your Edelbrock heads ported already? If not I would work with those first. If you are talking about something serious the AFR's are proven and Dart obviously has a good rep. It will be cheaper though to port the ones you got instead of buying new and then porting.
Old Feb 24, 2009 | 04:44 PM
BlackTA96's Avatar
Sorry man.
I have a few threads floatin around. Lookin to build a 383 with around 400rwhp. That was before I was going to replace the heads. Now that I've covinced my self to get rid of the edeljunks, think I might aim a little higher. This is going to be a nitrous motor. Plan sprayin around 2~250 shot. My pockets aren't that deep, but Im not lookin at get this motor done next week. I have time to save up.
Old Feb 24, 2009 | 04:47 PM
ulakovic22's Avatar
If you are going to sell the Edelbrocks shoot me a PM on price, I might take them.
Old Feb 24, 2009 | 04:50 PM
Puck's Avatar
+1 How can we make a suggestion with ZERO information??
Do you want a stump pulling street stroker? High rpm autocross monster? Nasty barely street legal drag setup? Stock cubes? Stroker? Turbo? Nitrous? NA?
Old Feb 24, 2009 | 04:53 PM
Puck's Avatar
Originally Posted by BlackTA96
Sorry man.
Much better - by the time I posted my reply a few more posts popped up
Old Feb 24, 2009 | 04:57 PM
SoxXpupPeT's Avatar
Originally Posted by chavez885
LT4 heads / Cam
i didnt scroll down all the way. i hit myself on the forehead for thinking someone would Actually suggest that combo. AI 200's or LE 2 or 3's
Old Feb 24, 2009 | 05:24 PM
Elliott's94Z's Avatar
LE2 heads are a nice choice as well.
Old Feb 24, 2009 | 06:03 PM
slomarao's Avatar
LE3's
no need for heads that big unless your building a racecar
Old Feb 24, 2009 | 06:51 PM
C5042081's Avatar
best budget would be to port the heads on it now
If you want to spend some $, afr is a nice setup
Old Feb 24, 2009 | 08:33 PM
rdel2006's Avatar
I was thinking of purchasing the eldelbrock lt4/intake,cam and heads for my 95 trans am. with 58mm throttle body 30lb fuel injectors ... sound like a good combination ?
Old Feb 24, 2009 | 08:43 PM
BlackTA96's Avatar
seeing the results from the AI 200cc heads looks like i might go that way. I just need a set of stock heads to use as a core.
Old Feb 24, 2009 | 08:46 PM
Originally Posted by slomarao
LE3's
These would not be a wise choice for his application.Really meant for a built bottom end. Read up on the LE3's
http://www.elliottsportworks.com/lt1.html
Old Feb 24, 2009 | 08:48 PM
Now those would be a nice set to go with. Heard nothing but good things.
Old Feb 24, 2009 | 09:33 PM
C5042081's Avatar
you will see much better gains from porting the stock heads and matching that to a cam LE and Ai are a few that make proven packages, among others , in my opinion edlelbrock is not worth the $
Old Feb 24, 2009 | 09:44 PM
LT1_Fireman's Avatar
LE ported Trickflows.
