need a little advise
And apparently you can't even realize that some info, while not an ideal solution, is actually not incorrect.
Sorry you haven't been around enough to know some of the tricks to get things cheaply done, so by all means go ahead and call a friend if you're stranded, or pay for a tow. I'd much rather Redneck it for a few miles
Not asking you to like my ideas, just asking you not to be stupid about it. Again, it was merely a "haha you can use this, but really don't" suggestion. If you consider the users here to be dumb enough to use cardboard as a perminant measure, then you clearly have little faith in your fellow LTx brethren.
You didn't bother to read the rest of the thread again apparently.
I read the entire thread when I made my first post, thanks. Why do you think otherwise?
1) It was simply an example as to the material you could use given the location and so forth.
Why didn't you mention you were suggesting it as a temporary fix in the first place? Did you go assuming people would think you were actually serious? Why didn't you suggest deer skin? Maybe some cotton underwear? I've got some spare tool-box liner...can I use that?
2) I was not implying that he should do that, as doing such would be a very temporary measure.
Then why didn't you say so? You could have avoided my response entirely (and responses from others, I'm sure), if you just said so! Looks to me like you're back-peddling to try and cover your own credibility (whatever you have left anyway) because what you suggested was ludicrous.
3) If you're in a pinch and stranded w/o any proper gasket material (gasket paper or rtv), this can suffice for 10mins to a few hours, whatever it takes to get you home.
Where did anyone mention this (prior to your post) about using it as a temporary solution? The OP asked what he could use to seal his EGR. He didn't mention a temporary fix; in fact he wanted a permanent fix, because he's installing EGR block-off plates, which is permanent.
My buddy has done it, and I can guarantee that he know a hell of a lot more than you ever will.
Once again, you rely on other people's experiences rather than your own. And maybe he does know more than me...you sure as hell don't.
It's not like I or he would EVER EVER do it to someone else's vehicle (ie a customer) and send them on their merry.
So what in the hell makes it okay to suggest to someone else then!?!?!?!?!??!
I'm sorry - but I post on forums to provide ideal solutions and proper techniques...not asinine redneck fixes.
Thank you for basing MY experience on my relatively low post count and your own speculation. I might have you know that I've been a tech moderator on two forums for over 11 years and been a well-respected member on cz28.com for 8 years. Not to mention the actual real-world experience I've earned that you definitely lack. And about red-necking it for a few miles? I don't like to cut corners for cheap **** - I build reliable cars that don't amazingly blow out EGR gaskets.
I don't like your ideas. Neither do other members here - I'm not the only one who feels the same way. I've received FOUR PMs from other members in the short time I've been on this forum regarding the shitty advice you offer, and thanking me for the corrections to your garbage responses. I can happily forward them to you if you like.
I have more faith in the LT1 owners that have the ***** to ask for help and start a post, or admit when they are wrong. What I DON'T have faith in is jackass pretend-know-it-alls like yourself that put on a dog and pony show and don't admit when you're wrong.
Glad we had this chat though! Don't forget to forward those PMs so I'll know who's threads to not bother with.
Oh and you can add me to the list of people to "not bother with".
You guys should start another thread to fight in so i dont have to weed out the bullsit from the help.
