30# Fuel Injector Install...
Old Feb 28, 2009 | 01:43 AM
Z28Camaro30Ann's Avatar
Default 30# Fuel Injector Install...
Ok, I have 30# ford fuel injectors I want to install on my SS Camaro...I can not conduct a tune on it until after I get my cam installed...would it be ok to go ahead and install those injectors now, or wait till I can tune it???
Old Feb 28, 2009 | 02:02 AM
96lt1m6's Avatar
why bother, they will be coming back out agian when your cam is installed. are youe existing injectors bad?
Old Feb 28, 2009 | 08:05 AM
not that I know of, but why will they be coming out when I put the cam in???
Old Feb 28, 2009 | 08:36 AM
myltwon's Avatar
because you have to take off the fuel rail, to take off the intake, to take out the lifters, to take out the cam
car will run like a pig with bigger injectors and a stock tune
Old Feb 28, 2009 | 08:44 AM
DAVE00's Avatar
Don't run that car without tuning for them if you do install them. You will severly wash your cylinders with gas cause you will flood the motor with gas. Trust me I've done it before and changed oil with gas in it. Just wait until you have it all apart for the cam swap and then throw them in there when you are putting it all back together and make sure you have a tune before you fire it up. Just my opinion.
Old Feb 28, 2009 | 08:46 AM
Badazz 97 TA's Avatar
you dont have to take off the fuel rail to take the intake manifold off
but i do agree on waiting until you get the cam in and then just get it all tuned at once. all your going to do is make it run like crap and burn more gas if you do them now.
Old Feb 28, 2009 | 09:14 AM
Ericbigmac83's Avatar
Don't swap injectors without tuning the motor!
Old Feb 28, 2009 | 11:39 AM
Smokinlt1's Avatar
Yeah I was gonna say you dont have to the fuel rail off to take the intake off but Badass beat me to it. I would wait till tune to swap injectors, very easy to do.
Old Feb 28, 2009 | 01:32 PM
LS1 Eddie's Avatar
I actually made this mistake and drove the car untuned. I was lucky to not do any damage. Good advice.
Old Feb 28, 2009 | 09:26 PM
myltwon's Avatar
well if you don't want to use a fuel line disconnect tool you have to
Old Feb 28, 2009 | 10:22 PM
robsquikz28's Avatar
u need a tune for bigger injectors it wont run right and you will be just dumping fuel in and ses may come on too....dont do it
