Piston Selection.
Old Mar 2, 2009 | 12:34 PM
BlackTA96's Avatar
Default Piston Selection.
Alright guys. I've got my crank and rods squared away. Now its time for pistons. Whats a good forged piston that'll handle a 250 shot. also rings?
Old Mar 2, 2009 | 12:46 PM
ss.slp.ls1's Avatar
JE or Wiseco forged aluminum pistons.
Flat tops w/ valve reliefs (for NA)
4.030" (assuming you are boring .030" over)
Someone will chime in with suggestions.
Old Mar 2, 2009 | 12:52 PM
BlackTA96's Avatar
So what static comp ratio would i be looking at with a flat top piston?
Old Mar 2, 2009 | 01:05 PM
RamAir95TA's Avatar
Need head volume, stroke, bore, deck height, piston valve relief, and head gasket thickness to determine a ballpark SCR.
Old Mar 2, 2009 | 01:32 PM
BlackTA96's Avatar
3.75 Crank
6" rod
4.030
stock head volume and deck height.(head volume is I believe 58cc? not sure on deck height)
head gasket is not yet bought.
Old Mar 2, 2009 | 02:39 PM
RamAir95TA's Avatar
3.75 Crank
6" rod
4.030
Stock heads are 58cc, stock deck height is anywhere from .020" to .030" (reports of being slightly varied).
Using a piston with a -5cc relief and stock head gasket, you're around 10.8:1. Stepping up to the Impala head gasket (.029") will result in 11.5:1.
But keep in mind that SCR is just an arbitrary number - you should be more interested in your DCR.
Old Mar 2, 2009 | 03:19 PM
Stroked97TA's Avatar
I like SRP and have never had a problem with them. It depends on your budget. RamAir is right about SCR and DCR. Your dynamic is the number you want to work with.
Old Mar 2, 2009 | 03:51 PM
BlackTA96's Avatar
Yea. Im gonna talk over my dynamic with AI when i get my custom cam. Figure if I get a ball park of 11.5:1 or so static that I can work with AI to the dynamic where I want it.
 Michael S. Palmer
Old Mar 2, 2009 | 04:43 PM
FASTFATBOY's Avatar
For a 250 shot you need a tooled steel top ring, like a Hellfire.
Old Mar 2, 2009 | 05:26 PM
grn95t/a's Avatar
built mine to handle a 300 shot. used je nitrous pistons w/tool steel pins and hell fire rings.
Old Mar 2, 2009 | 05:33 PM
ss.slp.ls1's Avatar
Good to know what I'll need to use...
Old Mar 5, 2009 | 08:46 AM
BlackTA96's Avatar
How much did you pay for those je nitrous pistons??
I can't seem to find them.
Old Mar 5, 2009 | 09:59 AM
grn95t/a's Avatar
they were right at 800.00 for the pistons and 125.00 for the wrist pins. so 925.00 basicly. my engine builder buys je direct. so i'll try and get a series name, ie; 23* extreme duty flat top, etc...
Old Mar 5, 2009 | 11:22 AM
BlackTA96's Avatar
alright. sounds good. thanks man
