Bolt On LT1 in the 10s
Old Apr 21, 2009 | 12:23 PM
AChotrod's Avatar
I think it could be done. It will take a ton to do it, but it can be done.
Old Apr 21, 2009 | 12:27 PM
kezy219's Avatar
I know nitrous is a power adder but if it were on a stock motor. Is there any kind of record for stock motor cars (meaning heads cam all internals stock)
Old Apr 21, 2009 | 12:30 PM
ss.slp.ls1's Avatar
I read a quote a while back that was along these lines:
"Drag racing is a money game, how fast do you want to go?"
Old Apr 21, 2009 | 02:36 PM
z28rob18's Avatar
your only as fast as your pockets are deep
Old Apr 21, 2009 | 04:04 PM
slick1851's Avatar
Originally Posted by kezy219
is nitrous considered a bolt on?? Because it is not an internal upgrade? Because if so i would think a stock motored lt-1 could go 10.50 with the right supporting modifications.
power adder!
Old Apr 22, 2009 | 12:39 AM
kezy219's Avatar
yes POWER ADDER thank you i said i understand that, but is there any type of record... for a stock motored car with a power adder considering the fact that you can only go so far with boost and such with a POWER ADDER
Old Apr 22, 2009 | 10:17 AM
ZFan88's Avatar
i'm sure it's been done before. do a search in the lt1 section or the n2o section if you really want to find it
Old Apr 22, 2009 | 02:31 PM
CamaroRacing12's Avatar
i believe the power adder record for a stock LT1 is 10.68... and its a procharger setup, i believe...
my long term goals r to hit 11.80 or faster bolt on only (the long standing bolt on only record prior to this past season) then throw a dual stage nitrous setup on it and see what happens! hopefully beating 10.68, then build a real motor when this one blows up
 Michael S. Palmer
Old Apr 22, 2009 | 02:41 PM
Kmaroman's Avatar
I could see it if a bolt on lt1 motor was swapped into something lighter
Old Apr 22, 2009 | 06:07 PM
my94blackz's Avatar
2900 LBS, pull the stock motor down and balance it, big ole stall, all the bolt ons, one of those light moser rears, take the wiring harness apart and pull all the not needed wires out.
I think its possible. Search gismo I think he has went 6's in the 8th.
Old Apr 22, 2009 | 11:41 PM
kezy219's Avatar
10.68..... i think i can beat that =)
Old Apr 27, 2020 | 02:08 PM
  #32
Chopstix's Avatar
There is one coming
And yes I know this is a very old thread.
Old Apr 27, 2020 | 03:17 PM
  #33
transbird95's Avatar
That is a damn good looking car! What hood Is that?
Old Apr 27, 2020 | 05:48 PM
  #34
Chopstix's Avatar
VFN to the windshield
