pushrod lenght???
Old Mar 5, 2009 | 03:01 AM
RaM AiR 97's Avatar
Default pushrod lenght???
well here i go again my buddy told me to get a hold of stock lenght pushrods. which are 7.200 am i right and which one would u guys recomend as far as brand and if you could get a hold of a part # for me that would be great. some say for use with guide plates other say .065 in. or .080 in. wall thickness. what the hell do i get it will be a cam only le2 cam please help guys already want to be able to drive it
Old Mar 5, 2009 | 05:43 AM
96LT1355Z28's Avatar
http://www.elliottsportworks.com/policy.html
Contact Lloyd, if your using his cam he can help you setup your valve train correctly. Pushrod legnth can make a difference in power and efficency!
Old Mar 5, 2009 | 06:50 AM
DAVE00's Avatar
Measure, Measure, Measure. If you are unsure of the actual length you will need then even Elliot will tell you to measure. As to the brand the Trickflow's are good and so are the Comp Chrome Molly. What ever you get make sure you get a hardened push rod. Good luck and let us know what you find out.
Old Mar 5, 2009 | 01:31 PM
ss.slp.ls1's Avatar
After you verify that stock length pushrods are what your setup needs:
http://store.summitracing.com/partde...0&autoview=sku
Part #: 21407200
Trick Flow 7.2" length 5/16" chromemoly pr's. Same ones I am using.
