What's the trick??
Old Mar 13, 2009 | 12:21 AM
alconk's Avatar
Default What's the trick??
My car is leaking oil from the seal in the timing cover where the shaft goes through to drive the water pump. When I replaced the opti I replaced all the seals in the timing coverbut right off the bat it started to leak. And I even bought a new shaft that pokes through thinking it might have a wore spot. I did notice that it was kinda loose, a little play sideways motion in the seal. So what's the trick to keep it from leaking? The seal is GM along with everything else.
Old Mar 13, 2009 | 12:35 AM
ss.slp.ls1's Avatar
It's probably because you didn't keep the lip of the seal facing inward.
There are a couple of things you can do. One that I have heard of is using a sharpie marker body slipped over the water pump drive shaft. You have to find one the right size. Or you can try to find some plastic that will slip over the shaft. Basically, you have to stop the shaft from pushing the lip outward when you seat the seal on the cover.
Old Mar 13, 2009 | 02:55 AM
alconk's Avatar
When you say keep it inward do you mean towards the timing chain?
Old Mar 13, 2009 | 05:20 AM
gatorhead's Avatar
There is an article with pics on cz8 with a sharpie "tool" made to do this, it keeps the seal the way it is supposed to be without tearing it.
Old Mar 13, 2009 | 08:56 AM
SS RRR's Avatar
Village Troll
An equivalent sized socket soaked in oil which is the same diameter as the splined shaft will also work.
Old Mar 13, 2009 | 10:26 AM
ss.slp.ls1's Avatar
^Yes.
Old Mar 13, 2009 | 10:35 AM
C_Rules's Avatar
u have a link. my car leaks a little oil from the same spot.
Old Mar 13, 2009 | 05:46 PM
gatorhead's Avatar
here ya go http://www.camaroz28.com/forums/show...hlight=sharpie
Old Mar 13, 2009 | 05:48 PM
ss.slp.ls1's Avatar
Nice, good pic too.
Old Mar 13, 2009 | 06:59 PM
I8ASaleen's Avatar
Get an E-WP and do away with that hole
