cam only
Old Mar 17, 2009 | 08:56 PM
buckner01's Avatar
Default cam only
okay i may have just gotten a second job, so i can get some stuff for the firebird, so far ive got, headers, ory, cutout, cheap homemade short ram intake, air foil, and shift kit, i think im buying a hypertech programmer on friday. heres the question, how would this car run with a cam only setup, if i added a throttle body, mass air, and a good cold air, and what kind of cam should i run, like durations, and lift. i may also put a 100 shot on it.
Old Mar 17, 2009 | 09:33 PM
DAVE00's Avatar
With stock heads and internals/bottom end an off the shelf is a good choice as they have proven results - like the CC306 or GM847 (streching it). Also if you want your car to be emissions legal these cams are not for you only if your area requires it. Lastly, stay away from the programmer as for about half the price you can have a custom tune done my PCMforless.com and they will tune way more than the hypertech can touch. Just visit their website for more info as they have helped hundreds of people here. Good luck and do a search you will find lots of good info on these cams.
Old Mar 17, 2009 | 10:03 PM
StealthFormula's Avatar
https://ls1tech.com/forums/lt1-lt4-m...wap-guide.html
Old Mar 17, 2009 | 11:00 PM
justin's Avatar
please dont waist your money on a maf. just the stock one. pcmforless were ranked like 2nd in the world for mail in tune so dont buy hypercrap (been there done that). lt4 hotcam kit is great for stock.
Old Mar 17, 2009 | 11:28 PM
myltwon's Avatar
no on hypertech
no on maf
do you have emissions? if so cc503 is a perfect candidate, though custom cam from LE would be my first choice unless u find a good deal on a used cc503
Old Mar 18, 2009 | 12:23 AM
Chris18927's Avatar
i run the cc306 with pretty much the same mods you haveand with 1.6 rr and i put down 342 hp through a stalled a4 (which may have had bad clutches when i had it on the dyno)
Old Mar 18, 2009 | 12:27 AM
za355tx's Avatar
A custom cam would be well worth it. Lloyd Elliott or AI would be a good choice. You should be careful with size though because the stock bottom end won't handle high rpm forever. In my opinion an 847 may be a little big. Some people do it with stock heads but your low end power will suffer. Something along the lines of a cc503 would be a great dd cam that will do you fine along with some good valvesprings. If you are doing a cam I would add some 1.6 rr non self aligning with some good pushrods and guideplates to handle the rpm. The stock stuff isn't really meant for much more than stock although some have gotten away with it. A bunch of guys are making 350rwhp with the 503 and supporting mods. Definately no on the hypertech. You can get a good mail order tune for far less. A MAF would be a waste of money too. Also the stock throttle body with airfoil can support more than 400 hp so with a cam only it's not something I would spend the money on. Hope this helps.
Old Mar 18, 2009 | 12:29 AM
gregrob's Avatar
If I was set on off the shelf it would be the CC503 from what I've read.
The 226.234 from AI seems like a better choice. They say it has the same driveability with more power and a better powerband.
 Michael S. Palmer
Old Mar 18, 2009 | 07:10 AM
buckner01's Avatar
wow lots of responses and help thanks guys, well i think ive decided that i wont get the tuner, i can probly take that cash and get a cam or rockers for it, with a good cam for stock internals is a bottle a bad idea, im planning on running a 100 shot.
Old Mar 18, 2009 | 07:46 AM
buckner01's Avatar
also what specs, i know there are a few potions, i saw the head cam guide, it seems to help a lot, and no i dont have emissions, not here anyway.
Old Mar 18, 2009 | 08:17 AM
dlk1950's Avatar
You should be able to run a 100 shot no problem..
Old Mar 18, 2009 | 08:44 AM
sdm1234's Avatar
Remember to get new springs and pushrods with that new cam. I don't recommend the cc306. It's based off of very old technology. Granted it makes good power, but now-a-days there are better off-the-shelf options. Here's a quote from another forum:
The CC306 cam is ground on technology that is over 20 years old. The CC306 is effectively all bark and no bite. There are much, much better cams available for LT1's that will provide much more power, much better idle characteristics, and better overall driveability.
The CC306 is listed as 230/244 @ .050", .510"/.540", 112 LSA. With that much spit in the duration and that little of lift, the CC306 is a very choppy cam that is very soft down low. The nose radius and flank rates of this cam are also off in relation to the LSA and lift. In addition with a 244 exhaust valve duration and .540" of exhaust valve lift on a 112 LSA, you are going to have a significant overlap without the effective intake or exhaust lift to support it or the intake duration to support it.
But lets look at this in even more deatail.
There are a few ways to calculate degrees of overlap. I will use the advertised duration and lobe separation angle method since I do not know offhand the specific IVO or the EVC timing of the CC306 camshaft.
First you add the advertised intake and exhaust duration together. Then you divide that sum by 4. Then subtract the LSA. Then multiply that by 2.
290+307 = 597
597/4 = 149.25
149.25-112 = 37.25
37.25 * 2 = 74.5
So the total valve overlap is approximately 74.5°. Like mentioned above, the profile of this cam cannot effectively support the overlap. Thus you end up with a rough cam that doesn't make really good power for what it is.
Old Mar 18, 2009 | 08:45 AM
DAVE00's Avatar
LOL - Didn't even see the MAF. X3 on no maf as the stock maf is the best way to go. Tons of tuners also swear buy it and say the Graneilli is crap and way difficult to tune with. Lastly, make sure you save money in your budget for a tune either dyno or mail order from PCMforless as this will greatly optimize your setup.
Old Mar 18, 2009 | 11:56 AM
JB_97ws6TA's Avatar
I am a fan of the lunati cams I went with the 60121 for emissions reasons, great all around cam
Old Mar 18, 2009 | 12:10 PM
sdm1234's Avatar
Great minds think alike. That's the one I just went with!
Old Mar 18, 2009 | 01:07 PM
rickreeves1's Avatar
I'm finishing up my cam install Saturday. I went with a custom LE non-emissions cam. 226/234 565/565 109LSA You will get excellent support with Lloyd. I've been running a 125 shot for a while. I plan to keep spraying it with the new cam. Maybe this will help also.
https://ls1tech.com/forums/lt1-lt4-m...lp-needed.html
Old Mar 18, 2009 | 05:39 PM
buckner01's Avatar
im looking up specs and it looks like the comp cam cc503 is not the same specs as listed in the "stock head cam/cam swap guide" unless im looking at the wrong thing, any ideas, i would like to get the most power out of the stock heads, i will put in roller rockers, and probly behive springs.
Old Mar 18, 2009 | 05:46 PM
The cc503 is a 224/230 .503"/.510" 112lsa...In the guide its listed at 224/230 .537"/.544" 112lsa w/ 1.6RR's because virtually everyone runs 1.6RR's when doing cam swaps which boosts the list. Not to be confused with the cc305 which is a 220/230.
Old Mar 18, 2009 | 05:58 PM
buckner01's Avatar
okay gotcha, i didnt know that 1.6 rockers raised lift. so if i got the cc503 cam, a set of roller mechanical lifters, roller rockers, 100 shot, 3200 stall, and 3.73s, could i be in the 11s? maybe low 11's?
Old Mar 18, 2009 | 05:59 PM
buckner01's Avatar
oh and a good set of springs
