Coolant leak HELP!
Old Mar 18, 2009 | 03:45 PM
shutzero's Avatar
Default Coolant leak HELP!
Replaced my water pump and i got a leak at the inlet hose. The upper radiator hose that goes into the water pump leaks right at the end. I replaced the house and put a good "constant torque" clamp that really clamped it down. It did not cut into the hose and the hose is seated nicely. not sure what else could be the problem. its a slow leak but enough where i have to add a little coolant every couple days. any ideas?
Old Mar 18, 2009 | 04:10 PM
ss.slp.ls1's Avatar
I would get a pressure tester and pressurize the system with the car cold and look and feel for where the leak is exactly coming from.
Old Mar 18, 2009 | 06:17 PM
shutzero's Avatar
i did,pressurized it to 15 psi and got a dribble coming from the end of the hose. idk how to stop it. the hose is clamped nice and tight
Old Mar 18, 2009 | 06:19 PM
ss.slp.ls1's Avatar
Hmmm, I don't know, maybe its leaking and the water runs where the top of the hose goes. Other than that, I don't know why it's not sealing.
Old Mar 24, 2009 | 06:36 AM
shutzero's Avatar
im thinking theres a compression leak in one of the head gaskets. leak down test will confirm this and will be done this weekend
