injectors ?
Old Mar 18, 2009 | 04:21 PM
bad99transam's Avatar
Default injectors ?
what size and make injector would be good for a 400rwhp lt4
if possiable a part number? Thanks
Old Mar 18, 2009 | 04:26 PM
robsquikz28's Avatar
anything below 42lb injectors will be adequate enough depending on prices but 30's will work too....
Old Mar 18, 2009 | 04:28 PM
Kmaroman's Avatar
What color are the stock injectors on the top of them, you know where the 2 wires plug into them?
Old Mar 18, 2009 | 04:55 PM
ss.slp.ls1's Avatar
I'd get some SVO 36# injectors.
Old Mar 18, 2009 | 05:01 PM
za355tx's Avatar
At least 30's, 36's would be good, even 42's would be good. Personally I went with 42's just in case I went bigger and better I already have injectors that will handle the extra power.
Old Mar 18, 2009 | 07:45 PM
Formula350's Avatar
Factory? All GM injectors are black (either all, or top and bottom). Ford varies, then again most all Bosch I've seen are colored.
Old Mar 18, 2009 | 07:49 PM
Kmaroman's Avatar
mines purple, what type could they be?
Old Mar 18, 2009 | 08:31 PM
Formula350's Avatar
LOL Doubtful, but if they're these purples, then 65#
http://images.google.com/images?hl=e...h+Images&gbv=2
I'd just check the code on the side and cross check it against this site:
http://users.erols.com/srweiss/tableifc.htm
Old Mar 18, 2009 | 08:35 PM
ryleag's Avatar
I have 42's and they work great.
