looking for a cam.
So if you have a .450 lift cam and your springs coil bind at .485 you WILL have spring valve failure(s).
Take your springs to a machine shop and have them measure your springs! They'll tell you you're open and closed spring pressure and what they coil bind at! And you'll find out if you have any bad springs! It's worth the few extra dollars even in a thrown together stock rebuild trust me.
Good info.
