looking for a cam.
looking for a cam.
Im looking to find a good cam for my caprice. I want a little more power than a LT4 hot cam but nothing to crazy, and something that will work fine with LT4 valve springs and 1.6 roller rockers. any ideas?
Changing the valve springs to Comp 987s, 918s, etc., will open up dozens of cam choices. Why don't you want to change them?
Actually with the heavy LT1 svalves the LT4 springs are NOT enough and they do not reliably fit the iron b-body heads.
The LT4 springs if they did fit are extremely weak, not up to the task of any modern aftermarket cams.
Some of the spring options that fit aluminum heads do not fit the iron so be careful choosing.
The iron heads often have a HUGE valve guide to locate the springs from the inside. The problem this causes is many performance single sprigs(non-beehive) have a damper and locating the spring by the ID instead of OD leaves no room for the damper.
I have never handled the Vortecs but it would be reasonable to think GM would have handled those the same way as the LT1 iron heads.
Try whatever spring you have onhand and see if they fit the heads you are playing with.
A couple guys have claimed to get LT4 springs to fit LT1 iron heads hence the "reliably fit iron heads" disclaimer in my post. Been done, just can not be counted upon to work.
Long as I am posting again I will elaborate on the LT1 valves being heavy comment. The LT4 valves are hollow on the intake and sodium filled exhaust, good bit lighter than LT1 valves and that makes them easier to control.
I presume said damper is the coil on the inside there.
http://www.cranecams.org/images/down...0(PN96805).jpg
What's it's actual purpose, as in what is it dampening? I'll have to double check the springs on the Vortec and the LT1 ones I got to see if they have the damper in them, then test fit one.
Yes the sheet metal spring is the damper. Dampens spring harmonics. Some springs sold for the iron heads just have the dampers removed with mixed results on the spring life, sometimes they crack due to not having the damper, sometimes they are OK.
That is another thing about beehives, since the coils are all different they cancel out eachother's harmonics.
The best cam for your provided criteria is the LT4 hotcam. LT4 springs were designed to be used with the LT4 camshaft. Anything more aggressive will require more lift, beyond the capabilities of the springs.
Im so sick of people so stuck on this peice of **** cam when you can have a great one from A.I. or bret/ elliot
Looks like we won't have any problems with the stock springs on those Vortec heads
Cam that's in the other motor currently:
LT1 BBodies: 191°/196° 0.418"/0.430" lift 111° LSA
Cam in that 98 Vortec:
L-31 Vortec: 192°/197° 0.413"/0.427" lift 111° LSA
A hot cam wasn’t intended for a big body car, I clearly read what both of you posted. I’m not a fan of the hot cam, and its always suggested on this forum all the time.
I’m suggesting he gets something that is better suited for his car to get that big body moving better.
Why even bother using the lt4 springs and let that be your factor in how your setting up the car. Why have the springs hold you back from the cam you can use, your really limiting your options. You can find good deals on springs. Id be more worried about what kind of cam is going into the car, and what converter it will like. All that plays a big roll in how the cars going to perform, its spending a lil more to get a lot back
