where to find single wire o2 extensions?
Old Mar 21, 2009 | 12:36 AM
Crows93Z's Avatar
Default where to find single wire o2 extensions?
does anyone know where to find these? i can only find multiple wire extensions, which isn't what i need. or is there a heated o2 conversion somewhere for us single wire folk?
i'm pretty sure this is the problem i'm having.. it'd be great if i could find some local before this weekend's over, but i don't see that happening.
Old Mar 21, 2009 | 01:45 AM
harner's Avatar
I doubt you'll find them local. You're probably better off making them yourself. When I was looking for o2 extensions I saw a ton of people on the net who did it themselves.
Old Mar 21, 2009 | 01:58 AM
Crows93Z's Avatar
i was told soldering o2 extensions was bad, and i'm getting new o2 sensors, so i'd rather have an entire set of legit o2 sensors haha. i've thought about heated o2 conversion, but it just seems like one of those things i'd rather not have to set up all the wiring for and what not...
Old Mar 21, 2009 | 08:27 AM
cgroh89's Avatar
I soldered in extensions on the harness side with no problem. Id rather have a little bit of resistance in the wire than corrosion able to form on the connector contacts.
I have a 94 harness now to and they are extended on the harness side with no problem.
Old Mar 21, 2009 | 08:30 AM
Puck's Avatar
Go with the heated o2 conversion if you have LTs.
My coated Pacesetter LTs were keeping my single wire o2s from heating up enough to read accurately and was making my car run like crap. The heated o2 conversion from thunderracing cleared that up.
It comes with everything including a 4-wire heated o2, and was easy to install and wire. You need to get two kits, comes out to about $180 for everything you need.
Old Mar 21, 2009 | 09:30 AM
sepno77's Avatar
+1 had same problem here and heated o2's fixed it
Old Mar 21, 2009 | 09:32 AM
xx_ED_xx's Avatar
Yeah definitely go with heated o2's
Old Mar 21, 2009 | 09:50 AM
Crows93Z's Avatar
that seems ridiculous. your O2's are still in your collectors, which are going to get up to like 700 degrees.. it might take a little longer, but the car's gonna be running rich at that stage anyways, right?. my O2's were fine with my longtubes without being heated until they went out..
Old Mar 21, 2009 | 01:08 PM
Formula350's Avatar
You've got it a bit mixed up, it's the butt-crimp connectors that are bad for extending O2s, you're supposed to solder them You could always make your own extension too.
(website in picture source link, not a sponsor, goto the TBI/TPI section) EDIT: That's a single wire BTW, that's just a really black shadow is all
Get 2 of these, see if they'll sell/send your 2-4 un-crimped ends for inside the plugs and then 2 old O2 sensors. Cut the plugs off the old sensors and then take a length of wire, how ever long you need, and crimp the new ends on each side. Pull out the ones from inside the plugs and push the new wire inside till they click (there's a certain way, you'll figure it out when you remove the ones in them). VOILA! I wouldn't doubt that they'd even make you them, PM S10Wildside on the forums here.
Old Mar 21, 2009 | 01:41 PM
BALLSS's Avatar
www.innovativewiring.com
IIRC they make them
Old Mar 21, 2009 | 01:47 PM
Puck's Avatar
Coated longtubes put the o2 farther from the hot primaries, plus a free flowing exhaust like true duals lowers temps even more.
When datalogging, my car would take almost 10 minutes to get into closed loop from a cold start...in 90 degree weather. When it finally did go into closed loop, the o2 readings were erratic.
After the heated o2 conversion it goes into closed loop within 3 minutes and the readings are much more accurate.
The newer 4 wire o2s are also more tolerant to lead and race fuels then the old single wire style, and will last longer.
Old Mar 21, 2009 | 01:48 PM
Formula350's Avatar
IIRC they make them
Not unless it's listed somewhere else. I'm only seeing this one.
Old Mar 21, 2009 | 02:44 PM
BALLSS's Avatar
Ping Gary at Inovative...he can make up anything.
