New Opti-Wont Start
Old Mar 22, 2009 | 06:19 PM
MissLindsey's Avatar
Default New Opti-Wont Start
I just put in a new optispark today and now the car wont start. It will turn over and start to fire, but it never actually starts and runs. Where do I even start trouble shooting!?
Old Mar 22, 2009 | 06:22 PM
CAMJAG's Avatar
Was the opti the problem in the first place? I thought mine was but turned out the be the ICM (Ignition Control Module)
Check for:
Fuel Pressure
Coil
Icm
Opti
Old Mar 22, 2009 | 06:29 PM
Check for:
Fuel Pressure
Coil
Icm
Opti
Well i never had the problem of it not starting... my poroblem before was an extremely bad miss at WOT. Fuel pressure is fine. I never took the coil off so i dont think that would be messed up. I dont think its the ICM cause if it went out wouldnt it not be firing at all? And i replaced the opti with a Jegs brand opti. its brand new but i know they have been known to come broken.
Old Mar 22, 2009 | 06:50 PM
CAMJAG's Avatar
You are correct about the ICM. Check your plug wires too and make sure they are not damaged or worn out. Maybe pull a couple sprak plugs and diagnose them as well
Old Mar 22, 2009 | 06:52 PM
Well i replaced all my plugs and wires last week and it started up and ran just with the terrible miss.
Old Mar 22, 2009 | 06:56 PM
C5042081's Avatar
check all connections(retrace to see plug positions are correct), are you sure the dowel ping is seated in the right position?
it is possible to miss the slot and put it above or below
I am sure the odds of a bad opti are slim but dont rule it out,I had a brand new gm opti come doa
Old Mar 22, 2009 | 07:36 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
What year is your car? It's fairly easy to get the opti indexed incorrectly on 93's & 94's. I guess it's also possible on the 95+ cars.
Old Mar 22, 2009 | 09:51 PM
Its a 1995.
Old Mar 22, 2009 | 11:53 PM
gatorhead's Avatar
Check your opti wire harness.
Old Mar 22, 2009 | 11:59 PM
93TAJ.C.'s Avatar
Check and make sure you have all the wires going to the right plugs. It happens quite frequently
