gear ?
Old Mar 24, 2009 | 04:16 PM
snk-huntr's Avatar
Default gear ?
anyone know what gears are in my 93 6spd ta ? thanks..
Old Mar 24, 2009 | 04:45 PM
ss.slp.ls1's Avatar
Should be 3.42's.
Old Mar 24, 2009 | 07:05 PM
StealthFormula's Avatar
No 3.42's in '93 fellas...In '93 with the T-56's you have the M28 (2.73 rear gear) and M29 (3.23 rear gear). Check out your option codes and and it will tell ya which one you have.
Year 1993 (M28) / 1993 (M29) / 1994+ (MN6)
1st: 3.36 / 2.97 / 2.66
2nd: 2.07 / 2.07 / 1.78
3rd: 1.35 / 1.43 / 1.30
4th: 1.00 / 1.00 / 1.00
5th: 0.80 / 0.80 / 0.74
6th: 0.62 / 0.62 / 0.50
Old Mar 24, 2009 | 07:09 PM
My95Z's Avatar
Correct.
Kinda scary an M6 car with 2.73's!
Old Mar 24, 2009 | 07:10 PM
ss.slp.ls1's Avatar
Originally Posted by My95Z
Correct.
I swapped a T56 into my buddy's '98 B4C w/ 2.73's. He said it was garbage with those gears. He'll be swapping in a 3.42 rear end soon!
Old Mar 24, 2009 | 07:13 PM
Actually in '93 the tranny gear ratios were more aggressive so having 2.73's in an M28 '93 6-speed isn't like running 2.73's with a later 6-speed ('94-'02).
I edited this into my other post but this explains what I'm talking about...
The 2.73 and 3.23 M28 and M29's actually have a shorter 1st and 2nd gear than a later 6-speed and 3.42's. Unsure of the rest of the gears since I didnt do all the math.
Old Mar 24, 2009 | 07:29 PM
snk-huntr's Avatar
is the option code in the glove box?
Old Mar 24, 2009 | 07:30 PM
snk-huntr's Avatar
I found a mn6 and m29 in the glove box.
Old Mar 24, 2009 | 07:32 PM
RamAir95TA's Avatar
RPO codes for gearing -
GU2 - 2.73
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
Old Mar 24, 2009 | 07:34 PM
sepno77's Avatar
Correct.
i ran w/ a 2.73 in my M6 93z for 3 years. not bad on gas but not great for the drag.
btw you better double check your gears by spining the wheels and seeing how many times the drivshaft turns with 1 full wheel spin cause my code in my glove box said i had 3.23 and turned out i actully had 2.73 and ended up buying the wrong ring&pinion
Old Mar 24, 2009 | 07:42 PM
snk-huntr's Avatar
how many times should the drive shaft spin if I have 323,s ,the code was gu5.
Old Mar 24, 2009 | 07:47 PM
RamAir95TA's Avatar
For every rotation of the wheels, the driveshaft will turn 3.23 times.
If it says GU5, you have 3.23s. That simple (if you aren't drunk).
Old Mar 24, 2009 | 07:52 PM
sepno77's Avatar
Originally Posted by RamAir95TA
For every rotation of the driveshaft, the wheels will turn 3.23 times.
If it says GU5, you have 3.23s. That simple.
i think you got this backwards. with 1 full rotation of you wheel ur driveshaft should spin 3.23 times
Old Mar 24, 2009 | 07:57 PM
RamAir95TA's Avatar
Too many Captain and Cokes. Fixed!
Old Mar 24, 2009 | 08:07 PM
RedFire04's Avatar
GM didn't offer 3.42 gears for the '93 Camaro. It was either 2.73 or 3.23 for the MN6.
Old Mar 24, 2009 | 11:07 PM
My95Z's Avatar
Thats a good idea, the way these things blow 10 bolts you never know what has been swapped in place unless you are the original owner.
