95 LT1 with 86 style balancer?
Old Mar 24, 2009 | 04:49 PM
Just Bowties's Avatar
Default 95 LT1 with 86 style balancer?
I am rebulding a NON-Elelectronic LT1 already installed GM performance Parts Carb'd Intake and deleted Opti-spark and added CSR waterpump am going to try a OLD STYLE Balancer since LT1 is going into 86 Z-28 anybody already do this?LT1 balancer has no timing marks and wont line up with existing Accesorries in car.
Old Mar 25, 2009 | 05:34 AM
You Cant tell me Im the only person gonna do this? The Old style SFI balancers are alot less money and already have a keyway.
Old Mar 25, 2009 | 05:53 AM
GIZMO's Avatar
Was your motor neutral balanced without the damper or flexplate installed?
Old Mar 25, 2009 | 12:48 PM
Ken95Z28's Avatar
Basically it's a LT1 bottom end correct?
I used a SBC hub with a LT1 Balancer (ATI) If wanted to I could have used the SBC balancer and it would have worked.
Here are some pics, don't forget about the timing mark indicator as well.
Old Mar 25, 2009 | 03:24 PM
Yes its internally balanced ,What intake are you going to use?Thanks Scott
Old Mar 25, 2009 | 03:28 PM
What Timing set did you use Im on Third one and all seem Sloppier than any other SBC Ive ever seen,accurate cam timing is going to be an issue
Old Mar 25, 2009 | 10:23 PM
Ken95Z28's Avatar
Cloyes Double timing chain is what I'm running.
I would use a crank trigger setup, the timing would be pretty darn accurate.
I'm using a Super Vic Intake on mine.
Since yours is internally balanced your flexplate / flywheel would need to be neutral balanced as well. The front hub / dampner would be as well.
This is the completed motor.
Old Mar 26, 2009 | 05:29 AM
Nice Thanks For all the Info.Tonight Ill finish up hopefully,are racing season starts in 2 Wks.You race at Tulsa dragway?
Old Mar 26, 2009 | 11:07 AM
Ken95Z28's Avatar
Yes I do race at Tulsa Raceway.
I run in their Bracket Program.
Old Mar 26, 2009 | 06:36 PM
It looks Like the Steam Tubes are Running back into Radiator,I was wondering what I was gonna do with them.
Old Mar 26, 2009 | 06:41 PM
Is your set up pretty consistent,Im putting my LT1 in an 86 Z-28 for my son who is in his last year of Jr.Dragsters and he wants to run a door car this year so I hope this works out if not He will have a pretty stout street car anyway,
