74 c10 project
Its going to be fairly easy as far as bolting it in goes, pretty much all Id need to pick up is a driveshaft and cross member from a short bed 80's 700r4 truck. What id like to do is keep my factory dash, But cut out the current gages, and install the same sized electric gages, to work with the lt1's wiring harness. This is kind of where Im at a loss. Also, the fuel system needed to run the FI on the lt1. I know I'll need 45+psi, But wondering how to use the stock tank, while having a return from the regulator. The last issue I really have is what stall to run on a heavy truck like this. I plan on running a cam only+bolt ons with this as well eventually.
Anyway, what do you all think, eh?
