Am i in denial
Old Mar 26, 2009 | 04:45 PM
RaM AiR 97's Avatar
Default Am i in denial
I finally got all the parts for a cam swap in my 95 formula and i was just looking around the engine while it was on and i saw the oil dip stick leaking out oil. PLEASE somebody tell me it could be something else. DENIAL DENIAL
Old Mar 26, 2009 | 04:50 PM
caldercay's Avatar
Possibly blow by? Do a leak down test. And check the PCV.
Old Mar 26, 2009 | 04:57 PM
MTBSully's Avatar
+1
replace the $5 pcv valve before you assume you have a ring problem.
Old Mar 26, 2009 | 04:58 PM
My95Z's Avatar
Just pull the oil fill cap while the engine is running and look for "puffs" of smoke comming out as you lightly rev the engine.
It could just be something random, don't jump to conclusion. Also sometimes the dipstick will leak a little where it goes into the block, just use a little silicon and it will seal right up.
Old Mar 26, 2009 | 07:38 PM
93TAJ.C.'s Avatar
Leaking from the bottom? I dont understand whats would be wrong Please somebody fill me in.
Old Mar 26, 2009 | 07:42 PM
95zsean's Avatar
Has it ever been out? If it has and it never had silicone put around it and taped in far enought it will leek. There is also a bolt that holds it in, check to be sure that is there.
Old Mar 26, 2009 | 07:50 PM
93TAJ.C.'s Avatar
I just had my motor out and it was leaking. It was in all the way too, just pull it out, clean it, and use "the right stuff", itll never leak again.
Old Mar 27, 2009 | 02:42 PM
AChotrod's Avatar
Leaking from top or bottom? I forgot to bolt it on b4 and it was leaking out the bottom. I just cut a slot in the bolt hole for the dip stick. Made getting it back on 100x easier.
Old Mar 29, 2009 | 12:53 AM
RaM AiR 97's Avatar
thats the thing it was coming out the top. i will do a compression check and replace the pcv once i get a chance from work this s$$ks. i hope its not the rings
Old Mar 30, 2009 | 01:31 AM
Z28Camaro30Ann's Avatar
I hope its just the PCV and not something worse......Good luck to you man!
