High idle on LT1
Old Mar 28, 2009 | 09:12 PM
MC94Z28's Avatar
Default High idle on LT1
Hi guys, on my 94 Z28, the cars idles around 1500 rpm, cold or hot. I've checked the throttle stop screw that the tab on the butterfly linkage would touch, the tab is touching the adjustment screw. Guessing theres some sort of electrical idle control solenoid somewhere? Whatcha think guys?
Old Mar 29, 2009 | 02:47 AM
palt1z28's Avatar
ever clean your MAF ( mass air flow sensor). with a break fluid. after i got my 383 put in and a good tune , we found that the z's idle was still a bit high. took that off cleaned it, ran like a baby. hope i could help. let me know
Old Mar 29, 2009 | 02:51 AM
Speed Density's Avatar
hashtagBMW
Dont do that.
If you have a tool that can log the car check your IAC (Idle Air Control) counts, thats what controls the idle speed. Fully open is 0 and fully closed is 160. Warm idle should se 30-50 counts.
Tony.
Old Mar 29, 2009 | 02:56 AM
palt1z28's Avatar
worked for me.
Old Mar 29, 2009 | 08:47 AM
monster81's Avatar
break fluid
Old Mar 29, 2009 | 09:30 AM
impaled's Avatar
Tony.
i agree 100% you should datalog it and check the IAC.
if not a bad vacuum leak could cause a high idle. that happened after i took a little too much meat off of the stock TB
so check vac lines.
did you do anything to the car recently?
