OTV plug wire kit???????
http://www.thunderracing.com
--Alan
I have since switched to conventional routing of MSD 8.5mm wires.
As long as you keep the wires close to the engine block you'll be fine. I'm using fiberglass heat sleeves for extra insurance.
You def. need OTVC wires if you have any kind of headers. Manifolds are only good for stock wiring. I built these wires when I installed my headers and it took about 2 hours. I can't imagine trying to use the factory wires or install aftermarket wires in the factory postion.
I did OTVC so I could build them and forget about any problems.
As long as you keep them insulated by the header primaries and keep them tucked towards the block, you'll be fine with almost any wire.
Hats off to your custom made kit though. I will be doing that when the time comes for new wires.
The wires are MSD 32129 (comes with the opti boot attached already, unlike the Taylor wires) and the Made For You 8mm looms.
I have been running the Thunder racing Taylor OTVC kit for a few months now.
No problems at all, and it looks clean and neat. Measure everything correctly and route it so theres no chance of burning the wires. Theres really no right way to do it, just as long it works for you.
I found two damaged wires tonight while I was changing plugs and adjusting rockers.
