a/c delete pulley
Old Mar 30, 2009 | 12:24 PM
buckner01's Avatar
Default a/c delete pulley
ok, i bought an a/c delete pully for my lt1 on ebay, and it got here today, but the pulley is plastic, anyone used these, and should i be concerned or will it be fine
Old Mar 30, 2009 | 12:25 PM
ss.slp.ls1's Avatar
I believe they are all plastic. I have one from Summit in my car. It has a plastic pulley and it works flawlessly.
Old Mar 30, 2009 | 12:29 PM
kierstyn's Avatar
Mine is from advanced and is plastic also works good so far!
Old Mar 30, 2009 | 12:40 PM
Formula350's Avatar
Yea, it's plastic just like the tensioner pulley.
I actually though about making one out of a tensioner pulley and some 1/8" sheet metal cut into a triangular piece like the !AC pulley setup. Can't see it not working, nut on the back of the sheet metal to bolt the pulley too and however many holes for the mounting to the bracket.
Old Mar 30, 2009 | 12:44 PM
AChotrod's Avatar
Im going to use the factory 1LE pc. Not sure if its plastic???
Old Mar 30, 2009 | 12:51 PM
CamaroRacing12's Avatar
on this topic... anyone have a factory 1le delete pulley? i need one
Old Mar 30, 2009 | 12:52 PM
AChotrod's Avatar
Pm larry at speedinc. They have a couple 1LE pcs in stock
Old Mar 30, 2009 | 12:57 PM
how much do they usually go for? $40?
Old Mar 30, 2009 | 01:00 PM
ss.slp.ls1's Avatar
I think I got mine from Summit for 26 bucks.
Old Mar 30, 2009 | 01:09 PM
yea i was looking for a factory 1le tho
Old Mar 30, 2009 | 01:37 PM
buckner01's Avatar
cool thanks for the help
Old Mar 30, 2009 | 01:38 PM
bombebomb's Avatar
I got mine from summit, it had quite a bit of play in it but a few washers fixed that.
Old Mar 30, 2009 | 02:09 PM
litch2004's Avatar
mine is also plastic. Mine didnt allign right so i had to space mine with some washers but the plastic pulley worked just fine untill i completly removed it and moved the alt down there in its place.
Old Mar 30, 2009 | 02:18 PM
explicit.muscle's Avatar
I bought the same one off of ebay, and I havent had a single problem with it. I didnt even need the shims that came with it. Fit perfectly
Old Mar 30, 2009 | 05:25 PM
yea i feel liek the fitment of the 1le will be better then any aftermarket one
Old Mar 30, 2009 | 06:23 PM
Formula350's Avatar
There's some on eBay last I looked, but if you're looking SPECIFICALLY for a 1LE one, you're asking quite a lot heh A 3rd Party recreation is a good bet though. After all, the LT1 has not been put into a 1LE vehicle for 12 years.
Old Mar 30, 2009 | 06:41 PM
AChotrod's Avatar
Larry told me they had a few factory pc's in stock.
