Bout to pull the trigger....
Old Mar 31, 2009 | 09:31 AM
BlackTA96's Avatar
Default Bout to pull the trigger....
...on building an LT1.
I was going to sell my lt1 and buy a ls1 roller and build a LQx. But I think I've decided to stick with the LT1.
I'm aiming for low to mid 11's on motor and well into the 10's on spray.
Build plans:
AI 200cc heads and custom grind cam
383 with cast crank and forged i-beams with mahle slugs
200 shot
I'm wanting to try and trade off my trans for a th400, but no luck so far.
You think that combo will get me where I wanna be??
Old Mar 31, 2009 | 09:45 AM
matt94z's Avatar
Yes, that combo should get you there, but get a th350 instead. It take less power to turn and a properly built th350 will last.
Old Mar 31, 2009 | 09:50 AM
SS RRR's Avatar
Village Troll
If built right you will be able to meet your goals no problem. Speed_Demon hit 120mph in the 1/4mi in his full weight Z28 without the proper gearing/tire combo on road race suspension with his AI/stock block combo.
Old Mar 31, 2009 | 09:52 AM
z28rob18's Avatar
yea that should get you there but AI is goin to reccomend goin with the trickflow 215cc heads for the cubes. but the 200cc should be fine
Old Mar 31, 2009 | 11:06 AM
BlackTA96's Avatar
Anyone know where to buy a rotating assembly with the stuff i mentioned^^^??
Old Mar 31, 2009 | 11:28 AM
z28rob18's Avatar
jegs summit a rotating assembly for a 1 piece main seal. you keepin this budget that y your goin with cast crank?
Old Mar 31, 2009 | 01:08 PM
BlackTA96's Avatar
Yes sir. Moneys tight now a days...
I pieced together a scat cast crank, eagle forged i-beams, and mahle power pak, and it came out to just over $1100.
Old Mar 31, 2009 | 07:46 PM
Z28Camaro30Ann's Avatar
Ok, so I am new to the world of heads....I have 190cc AFR Heads...what is the difference exactly between 190cc, 200cc, 215cc, etc in regards to power gains, durability, etc? Also I have been told AFR is a very good brand of head for the LT1, but what brand is better, AI, AFR, Trick Flow, etc??? Sorry for the ignorance...
Old Mar 31, 2009 | 07:54 PM
Puck's Avatar
I would not hit a cast crank with a 200 shot on top of an already stout H/C package.
Old Apr 1, 2009 | 06:40 AM
z28rob18's Avatar
i kinda agree.
and the heads afr are good heads but 190cc heads are a bit small for a 383. the difference between the sizes is how big the intake runners are. the bigger they are the more potential flow. and the more flow the more potential horsepower. more flow isnt always more power though. if you have a set of afr 190cc heads id call up llyod elliott and see wat he can do with them. im goin with the trickflow castings for my 383 they seem to be pretty nice heads
Old Apr 1, 2009 | 07:24 AM
BlackTA96's Avatar
It'll be on a progressive controler. Won't be all at once.
Old Apr 1, 2009 | 10:57 AM
97LT1's Avatar
Kudos for sticking with the LT1. Score one for the good guys!
