WICKED vibration at 80+MPH
At around 80+ mph i can start to feel a small shimmy through the transmission.. when I put the clutch in or shift to neutral, it gets REALLY REALLY BAD. the funny thing is you can hardly feel it if you are in gear accelerating.
all my co workers at my shop keep telling me its the wheels, but the guy said he straightened them. Should I call BS on the guy that fixed my wheels and check my wheels again? or is there something else wrong with my car. I want to get my car dyno'd but im afraid ill get denied because of this vibration. thanks!
haha. ill check them in a week when I feel safe touching the wheels haha.trans mount is fine. its a new poly one. ill check the U joints i had one replaced already
I've always put a light layer of grease on my torque arm bolts and use a large 1/2 drive breaker bar to tighten the bolts, not saying its the right thing to do but I've never had mine come loose.
How many miles are on the Trans? If its high milage check the output shaft bushing (where your drive shaft slips into the trans) for wear, you can simply push up and down on the front of the drive shaft to see if there is any extra clearance in the bushing.
Pontta: The only reason I mentioned rear end (not assuming that was directed at me since you said wheels) was that I figured with no torque load being applied the axles could have a bit of play in them and start to vibrate. Until the load[torque] is reapplied and that slack/play is taken up. Maybe he's launched too hard a few times >_> Not that ANY of us beat on our cars
