doing the brakes?
Old Apr 3, 2009 | 09:33 PM
camerory's Avatar
Yeah, like these guys have said you should get the 1998-2002 brake setup for the front. That setup is far superior to the 1993-1997 brakes because in 1998 GM upgraded to twin piston calipers.
I picked up the entire assembly for $140 from a guy on craigslist. I just installed them and it doesn't take too long. I just had a bit of a problem because my car was miss-aligned in the past. You will probably need to get your front end aligned afterwards.
When you remove your splindle from each ball joint be carefull not to damage the ball joint cover. I found after loosening the castle nut, thread it on the stud upside down and hit it with a hammer to push it out of the splindle.
Old Apr 3, 2009 | 11:11 PM
xx_ED_xx's Avatar
I cant wait to get my z06 c6 brakes on
Old Apr 3, 2009 | 11:59 PM
I8ASaleen's Avatar
How in the hell are you fitting C6 Z06 brakes on there???
Old Apr 4, 2009 | 06:50 AM
the_merv's Avatar
Veteran: Air Force
Probably with 18" Wheels..
Old Apr 4, 2009 | 08:23 AM
SoxXpupPeT's Avatar
^^^ what merv said
Old Apr 4, 2009 | 02:47 PM
nolimit5685's Avatar
awesome info from you guys...i am gonna try to hit my uncle's junkyard up this weekend sometime....army keeps taking my weekends away from me tho
Old Jul 29, 2009 | 09:56 AM
i finally got around to looking at some junk yards yesterday for ls1 front brakes...is there a dead give away to knowing a ls1 car? some cars were pretty mangled but i did see one that looked like ls1 brakes(from looking at pictures) however i was wondering if someone had a tip that would let me know for sure??
Old Jul 29, 2009 | 10:08 AM
killagt's Avatar
How do i know if my rotor is warp ?
Old Jul 29, 2009 | 10:09 AM
Bajapat's Avatar
the tear drop head loght covers.. or oval maybe anyways the side vents on the from quarter panels.. the tail lambs would be honey comb orther then the grid we have...
Old Jul 29, 2009 | 10:24 AM
are those differences the same even on the v6 fbodys 98+
Old Jul 29, 2009 | 11:32 AM
ss.slp.ls1's Avatar
Originally Posted by ss.slp.ls1
Go to a junkyard and find a '98-'02 Fbody, all of them should have the dual calipers, doesn't matter if it's a v6. Remove the spindles, calipers, rotors, everything as one. You'll have to pop the ball joints. You should be able to get the whole thing for under 200 bucks. Then buy the brembo blanks and hawks pads. Install everything, bleed the brakes, and enjoy a night and day difference of braking power.
I think he's talking about Trans Am's only. As far as Camaro's go, dead give away are the lights. LT1 cars have recessed lights. LS1 cars have the bubble lights or what ever you call them. Not to mention LT1 cars have flat hoods, LS1 cars have the contours in the hood extending from the head lights up. One more thing, tri-color tail lights started in '97+. So most likely if you see them, it's a LS1 car.
Old Jul 29, 2009 | 12:15 PM
  #32
chavez885's Avatar
Also know that the V6 and LS1 cars 98+ had the same front brakes, so if you find a V6 car, you can get the brakes off of it.
Old Jul 29, 2009 | 12:48 PM
  #33
ss.slp.ls1's Avatar
He knows that, cause I told him the same thing. He just needs help to spot a '98+ v6/v8 car at the junkyard...
Old Jul 29, 2009 | 12:53 PM
  #34
chavez885's Avatar
I'm sorry, I didn't see that post, but thank you for this relevant post!
Old Jul 29, 2009 | 01:04 PM
  #35
i shall have to keep the hunt goin.
Old Jul 29, 2009 | 10:12 PM
  #36
killagt's Avatar
Any one ?
Old Jul 29, 2009 | 11:16 PM
  #37
Any one ?
uneven wear on the pads/rotors? makes a warped sound when braking?
Old Jul 29, 2009 | 11:29 PM
  #38
JB_97ws6TA's Avatar
you will notice a pulsation in the pedal under braking
Old Jul 30, 2009 | 08:29 AM
  #39
the_merv's Avatar
Veteran: Air Force
It will kinda vibrate.
Old Jul 30, 2009 | 10:01 AM
  #40
SS RRR's Avatar
Village Troll
Depending on how warped you will feel a pulsating in the brake pedal and/or shimmy in the steering wheel when brake pressure is applied.
