sensor in oil pan
Old Apr 3, 2009 | 05:31 AM
97lt1z28's Avatar
Default sensor in oil pan
while removing my oil pan a i broke then sensor the inserts into the pan. Is this my oil temp sensor? Can someone let me knowe what its called so i can get a new one please.
Old Apr 3, 2009 | 05:41 AM
xx_ED_xx's Avatar
Oil level sensor
Old Apr 3, 2009 | 06:38 AM
leadfoot4's Avatar
Originally Posted by xx_ED_xx
Oil level sensor
Yup, see your dealer!
Old Apr 3, 2009 | 11:21 AM
ss.slp.ls1's Avatar
Oil level sensor
Yes, and don't put the new one on until you put the oil pan back in place.
Old Apr 3, 2009 | 11:50 AM
djjab57's Avatar
sorry for the high jack but i bought one of these senors by mistake, well i thought i was ordering the sending unit but got this. What exactly does the level sensor do? thanks and sorry OP for the high jack
Old Apr 3, 2009 | 11:52 AM
ss.slp.ls1's Avatar
The oil level sensor senses the level of the oil.
It's what sets the low oil light on inside the dash when your oil is low.
Old Apr 3, 2009 | 11:56 AM
Formula350's Avatar
Don't need to. We just had a thread on this and someone chimed in that they got one from a parts store, and I listed a P# from NAPA as well. Thankfully I still have that image I made!
OP: You can take this part number and goto another autoparts chain to cross reference. I'd just print that out, but if not just make sure to mention it's an Echlin brand.
Old Apr 3, 2009 | 11:58 AM
djjab57's Avatar
LOL i knew that i guess i had a brain fart. i was looking at it and was trying to figure how it works. it has a plastic part coming out with a plastic ring around it . the ring i guess floats and maybe sends a signal when it comes into contact with the part its around ???
Old Apr 3, 2009 | 01:02 PM
Formula350's Avatar
Yea, there's a magnetic contact encased in plastic and then a magnet on that float lever. Now, I'm not 100% sure which way it works but it either: Float is already in the contact position from floating, and when it drops low enough the arm falls and breaks the contact triggering the Low Oil condition. OR Float is... floating... and doesn't have contact with the switch, so it knows you have enough oil, but when it drops low enough, it makes contact and then triggers the Low Oil condition. See crude image to help lol
