how to diagnose a fuel pressure regulator
shbox site says what fuel pressure should be, might be worth taking a look. I cant really say if the FPR is bad. Since you don't have fuel on the vacuum side.
http://shbox.com/1/4th_gen_tech2.htm...essure_testing
#33
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Hi, I have same problem, there is not fuel coming out from FPR , the fuel pressure is 50 psi at idle and 60 psi without vacuum line....no fuel inyectors leaking, so I am 99% sure, my fpr is bad. The idle is a little high and some times I have to turn the key 2-3 times to get it start. My fuel pressure drops almost immediately to 0 psi when engine is not runnig.
What other symptoms do you have?
#35
#37
got the new fpr on...i cant tell yet if it fixed the problem but it actually does seem to be idling lower...ill have to throw a tech II on there to read rpms to see if it helped
#40
With a fuel pressure gauge hooked up and system primed with engine off does the fuel pressure drop to 0 immediately? If so, I would be willing to bet it is the check valve in the pump.
