Opti ?
Old Apr 9, 2009 | 12:25 PM
TX_LT1_Z28's Avatar
Default Opti ?
My brother has a 94 Camaro Z28 5.7L A4. He is going to replace his distributor (opti). He wants to know if there is a certain way for the new opti to go in place. Do u just put it in any way or does anything have to match up. Like for the timing to be right. It is a non vented opti..Thanx
Old Apr 9, 2009 | 12:38 PM
ss.slp.ls1's Avatar
It's a spline drive, see diagram:
http://shbox.com/1/93-94_opti.jpg
Old Apr 9, 2009 | 12:43 PM
TX_LT1_Z28's Avatar
thanks alot man
Old Apr 9, 2009 | 12:48 PM
ss.slp.ls1's Avatar
thanks alot man
No problem, don't know if you need these, but it might help you. You pretty much undo/remove stuff in this order:
http://shbox.com/ci/water_pump.jpg
http://shbox.com/ci/balancer_hub.jpg
http://shbox.com/ci/opti_mounting.jpg
Old Apr 9, 2009 | 05:13 PM
vipergtx500's Avatar
o and try not to break the new opti in half like i did
Old Apr 9, 2009 | 05:26 PM
Badazz 97 TA's Avatar
also, tell him dont force it on if it wont slide on!
Old Apr 10, 2009 | 02:19 PM
1badzee's Avatar
Opti R&R write-up
http://www.lt1engine.com/tech/93-97-...emove-replace/
