does any one have this cam
Old Apr 9, 2009 | 09:05 PM
1994TAguy18's Avatar
Default does any one have this cam
i put a comp cam 276, 290 .510 .510 and i havn't seen any one with this cam and i was wondering if anyone had the same cam and if i can get a sound clip. thanks
Old Apr 9, 2009 | 09:18 PM
96capricemgr's Avatar
Nobody goes by advertised duration numbers, post the .050" numbers and you might get some feedback.
Old Apr 9, 2009 | 09:21 PM
myltwon's Avatar
this is the cc305 (220/230 .510/.510 112 or 114lsa) I assume? advertised duration on the cc305 is 276/290
many people have run it in the past but its considered a pretty outdated grind, made on the older "lazy" magnum lobes. not to many people use it these days when better grinds are available for stock head cars
what are your goals for the car? supporting mods?
as for sound clips go here http://www.lt1engine.com/videos/tag/cc305
though I assume most are the 114lsa version since it has been around longer and is more commonly used
Old Apr 10, 2009 | 08:16 AM
vanilla89's Avatar
My old roommate has that cam in his camaro. It's a good street cam, it doesn't need a lot of converter and makes good T/Q from idle up.. It just don't have a good cam sound, not much more lope than a stock cam with 1.6 rockers.
