oil pan leak
Old Apr 11, 2009 | 01:56 PM
97camarolt4's Avatar
Default oil pan leak
Well I finally got my car running again after a year and half of sitting in the garage. Now I have a very small oil leak in the very front of the oil pan and also i have a rattling noise coming from the tranny. Once I think I get on top of the problems two more pop up. I guess back to saving up money to get it fixed. Once you get married, buy a house and have a kid its hard to put money into my toys.
Old Apr 13, 2009 | 07:15 AM
DAVE00's Avatar
Did you remove the TC or Oilpan at one time. If so when you put a new oilpan gasket on did you apply some RTV or the 4 corners and to the front and rear lips of the pan? This is what I had to do this weekend and now zero leaks.
Old Apr 13, 2009 | 08:03 AM
the_merv's Avatar
Veteran: Air Force
Maybe the Gasket in that area dried up. As far as the T56 goes..what kind of rattling noise is it making?
Old Apr 13, 2009 | 09:29 AM
wrd1972's Avatar
Mine has a tiny leak on the bottom front edge of the pan. Tried a light coat of RTV to seal it but no go. Might try a bigger glob of it next time. Pisses me off.
Old Apr 13, 2009 | 09:52 AM
the_merv's Avatar
Veteran: Air Force
If you have a leak already then you might as well take it apart and re-seal it that way. If you try to band-aid it, it will never work.
Old Apr 13, 2009 | 09:56 AM
93TAJ.C.'s Avatar
I there ever was a bandaid method, it would have to be a good cleaning and "the right stuff" It's like silicone but doesent need to be as clean, it pretty much sticks to evrything, Iv had to do it in a pinch before.
Old Apr 13, 2009 | 10:05 AM
wrd1972's Avatar
Yeah I will try that before pulling the pan.
