New headers installed
Old Apr 11, 2009 | 08:07 PM
dkishton1486's Avatar
Default New headers installed
Hey guys got my new headers installed today.
OH MY NO CAT....Shhhhh
Video
Old Apr 11, 2009 | 08:12 PM
RamAir95TA's Avatar
Nice. How was the install?
Old Apr 11, 2009 | 08:16 PM
actually it wasnt too bad.. The hardest parts were getting the dipstick tube back in and mocking up the straigh pipe to delete the cat. I almost gave up but I pushed myself through and im glad I did I got finished with it and drove it for 30 mins. Tomorrow im gonna go out and tighten the bolts up more
Old Apr 11, 2009 | 08:25 PM
1badzee's Avatar
Looks good. My buddy has those headers on his Impala. They're really nice actually
Old Apr 12, 2009 | 02:24 AM
SoxXpupPeT's Avatar
those look real nice man. ceramic coated i assume ? that primary off #2 looks like it gets in the way of the rear spark plugs abit tho :x
Old Apr 12, 2009 | 07:44 AM
Yeah to get to the #6 plug I gotta remove the dipstick tube to change out the spark plug. Yes they are ceramic coated
Old Apr 12, 2009 | 09:46 AM
Darnit... I hav an exhause leak somewhere I can hear it ticking its not too loud but I can still hear it. I tightened all the bolts as tight as I can.
Old Apr 12, 2009 | 10:37 AM
sceneiskeen's Avatar
Looks good, sounds mean.
Old Apr 12, 2009 | 10:53 AM
creepingdeath94's Avatar
I would put some of those heat sleeves on the spark plug wire ends to save yourself some headache down the road as well. The leak may be coming from the cat delete where those clamps are...just not squeezing it enough to seal perhaps? If it is coming from there, they have sleeve style exhaust band clamps that are like 3" wide and would seal the crack as well as clamp the pipes together.
Old Apr 12, 2009 | 12:08 PM
RamAir95TA's Avatar
Did you tighten them from the inside out?
Did you double check all of the spark plugs are seated tightly?
What gaskets are you using?
Keep in mind that headers amplify valvetrain noise, and the tick you may hear could be normal.
Old Apr 12, 2009 | 12:43 PM
No I did not tighten them from the inside out oops maybe I should have.
All plugs are good.
I used the gaskets supplied from edelbrock.
Yeah I do notice a valvetrain noise.. I wonder if my rockers need adjusted or not..
Old Apr 12, 2009 | 02:13 PM
sweetbmxrider's Avatar
sounds good. gotta ask, why get emissions fittings then delete the cat?
Old Apr 12, 2009 | 03:53 PM
Elliott's94Z's Avatar
Probably because putting on a cat at some point if he needs to pass emissions is a easy thing to do, where having to swap back all the emission fittings would be a S.O.B. It would require more work then most would want to do. A lot of guys out here will go through smog testing and once they pass, take the cat/s off for that next couple years until they have to go through the sniffer again.
Old Apr 12, 2009 | 04:26 PM
SoxXpupPeT's Avatar
did you use copper gaskets ? if so did you put them in the proper way ? the side with the high spots faces the header
Old Apr 12, 2009 | 06:03 PM
No I used the gaskets supplied from Edelbrock.. They did have a bump around the ports and I believe I put thoes towards the heads..Oops I think I made a boo boo
Old Apr 12, 2009 | 06:08 PM
yeah that would make sense. cats cost maybe 5 hp especially if you use a high flow though so i'd rather be legal and not get a potential ticket i guess.
Old Apr 12, 2009 | 06:19 PM
SoxXpupPeT's Avatar
you might have the gaskets backwards. its been a year since i did my headers but i think the bumps went towards the header. also. double check all your hook ups if you kept your EGR and AIR.
Old Apr 12, 2009 | 06:33 PM
RamAir95TA's Avatar
I honestly don't think it matters which side the bumps go. Most directional gaskets will tell you on the gasket itself which side goes toward what surface (head gasket, intake, etc.). If yours didn't say anything on them, I'm sure it doesn't matter.
Old Apr 12, 2009 | 06:37 PM
Yeah there were no marking on which side was up,down,out,in so I guess im ok.. Also it may just be the valvetrain noise im hearing because with it started I was under the car and I didnt hear anything leaking.. Also its loud as hell I went out for a test drive and there was a cop at the gas station filling up and I stomped on it and he couldnt do anything because he was in the wrong town all he could do was watch hehe.. But it sucked not being able to rapt the hell outta the car because im still in the break-in stage on the engine
Old Apr 12, 2009 | 10:44 PM
did you put any high temp copper silicon on the gaskets? that is usually a good thing to do. i would try to feel around by hand for a leak though. its usually pretty evident. that or some miles on the car will show carbon streaking.
