new lifters?
The run down:
Installed a CC305, w/ 1.6s Magnum rockers, only gained 23 rwhp from the last dyno result (I know dyno results vary and i think this one was slightly low, but anyway, read on):
I talked to a guy I know that knows LT1s very well. He was thinking my low power gain from my cam (23 rwhp) could be from my lifters. It sounds very reasonable. Here's why....My lift is about .543" intake and exhaust, and combined w/ the higher spring pressure, and the fact the stock lifters have 99,000 miles on them....
Just sounds like they could be compressing too much and not getting the full effect of the cam. You guys think that sounds reasonable? Should I replace them with the Comp Cam OE or Comp Cam R? What are the differences in those two lifters?
This guy had problems w/ his setup too, and finally narrowed it down to bad lifters, and repalced the lifters and gained 21 rwhp. I am thinking I might have a similar problem. Thanks.
