wow please help!
Old Apr 15, 2009 | 06:27 PM
red-_-z28's Avatar
Default wow please help!
i am having a hard time removing the spark plugs on the passenger side only...does anyone know what to do?!
Old Apr 15, 2009 | 06:34 PM
airfix's Avatar
Got from under the car with a wrench on the end of the spark plug socket.
Old Apr 15, 2009 | 06:39 PM
4THGENCAMAROFAN's Avatar
Yep that's about the easiest way to do it.
Old Apr 15, 2009 | 06:40 PM
djjab57's Avatar
HAHAHAHA this must be your first time !
Old Apr 15, 2009 | 06:48 PM
ss.slp.ls1's Avatar
Stay determined...
Spark plug socket, swivel heads, mini ratchet
Old Apr 15, 2009 | 07:25 PM
Formula350's Avatar
While it's slightly funny for us who've done it, it's only funny in the 'God, I feel your pain man' sort of way :\
I did it with my car on a shop lift and it was a pain in the ***, but the pass side was pretty decent on the lift. I think I managed the 2 and 4 from the top though.
Just wait till it's time to do the Pass side O2 sensor
Old Apr 15, 2009 | 08:43 PM
red-_-z28's Avatar
okay guys i got all them off from the top
Now im having troubles finding the arrow on the balancer to reach the TDC. Do you know exactly where this is located and do is there any other way of finding the TDC?
Old Apr 15, 2009 | 08:45 PM
RamAir95TA's Avatar
The arrow is on the front of the balancer assembly. It's small but easily noticeable.
Why do you need to find TDC?
 Michael S. Palmer
Old Apr 15, 2009 | 08:50 PM
red-_-z28's Avatar
do we have any pics?
and cause im adjusting the rockers, they are loose.
Old Apr 15, 2009 | 09:16 PM
red-_-z28's Avatar
come on guys!...help please
Old Apr 15, 2009 | 09:25 PM
slamm69's Avatar
This may sound retarded but it works: If you have small enough arms to go through the top use vaseline to lube up your forearm real good and you can slip it between the exhaust manifold and the strut tower.Like I said it sounds stupid but it works.I didnt believe it untill i tried it.
Old Apr 15, 2009 | 10:45 PM
red-_-z28's Avatar
i got the spark plugs..i just need to know where the arrow is to reach TPC!
Old Apr 15, 2009 | 11:08 PM
mj114679's Avatar
LOOK!!!!^^^^ red this!!!!
Old Apr 16, 2009 | 07:10 AM
red-_-z28's Avatar
I know!! I've looked and looked and still haven't found anything.
Old Apr 16, 2009 | 08:23 AM
phirepower's Avatar
Anyone else feel like lt1 owners are becoming less and less mechanically inclined?
Old Apr 16, 2009 | 08:35 AM
95greenmaro's Avatar
Have someone turn the motor over and put your finger in the hole for the #1 spark plug. when you feel the piston is at the top there you have it. thats how we have done it.
Old Apr 16, 2009 | 08:41 AM
Formula350's Avatar
It's because of the generation of kids growing up who haven't had to work on vehicles before, but still like these types of cars :\ Which is doubly surprising since this generation should know how to
Old Apr 16, 2009 | 08:47 AM
z_speedfreak's Avatar
that is retarded....use KY
Old Apr 16, 2009 | 08:48 AM
phirepower's Avatar
^ that makes a lot of sense actually. I just mean some of the questions on here from time to time make me wonder if the Op's even tried the task before posting it on the board
Old Apr 16, 2009 | 12:00 PM
ss.slp.ls1's Avatar
I used a chopstick inside the #1 cylinder spark plug hole to verify that it was at top dead center and I also looked at the rockers to verify that both the #1 int and #1 exh lifters were on the base circle.
