A few issues i need help with.
Old Apr 19, 2009 | 12:52 PM
F3RR3T's Avatar
Default A few issues i need help with.
I have a 94 z28
I need new window motors as they overheat and stop about 4 inches from the top. but the main issue is when they are all the way up and the door is shut they dont really seal against the seal around the window. makes a great place for a water leak. anyway to make them sit tight against the seal.
also how hard is it to replace the oil pressure sending unit?
Old Apr 19, 2009 | 01:07 PM
RamAir95TA's Avatar
Originally Posted by F3RR3T
I have a 94 z28
To fix the sealing problem you need to replace the window motor. Once the glass meets resistance on a weak window motor it will stop. The glass needs to push against the weatherstripping to seal. Additionally, if your weatherstripping is bad you may need to simply replace it.
The oil pressure sending unit is located behind the intake manifold on the driver side. You will need a special socket to remove it. If you have an early 1994 model, the pressure sensor will be above the oil filter on the driver side of the block.
Old Apr 19, 2009 | 08:50 PM
F3RR3T's Avatar
Ok thanks for the help
Old Apr 20, 2009 | 10:34 AM
djjab57's Avatar
On my 94 mine is under the car next to the oil level sensor
Old Apr 20, 2009 | 11:05 AM
ss.slp.ls1's Avatar
Default Oil pressure sensor
It's not too bad. You just need a oil pressure sensor socket.
'94-'97
http://shbox.com/1/oil_pressure_sensor.jpg
http://shbox.com/1/op_sensor.jpg
'93 & early '94
http://shbox.com/1/aux_oil_port.jpg
Old Apr 20, 2009 | 11:26 AM
djjab57's Avatar
If yours is the one on the back of the intake and havent bought one. I have a NIB GM Oil sendinding Unit for sale. When i ordered mine they sent the wrong one so instead of sending it back i kept it and now have it for sale . Let me know
Old Apr 20, 2009 | 12:21 PM
F3RR3T's Avatar
I will check when i get back from new jersey
