Edelbrock Shorties Flange Issue???
It should have come with another flange that you have to get welded at an exhuast shop. Make sure to retighten the bolts after the engine is run for awhile from inner to outer. Also with that flange make sure you get whatever you can to keep the bolt's in place b/c they will back out and you'll have a constant exhuast leak.
