start up smoke need help
Old Apr 23, 2009 | 08:55 AM
RED94Z28's Avatar
Default start up smoke need help
Whenever i first start up the car there is some brownish black smoke that comes out for about 2 minutes. It pretty much smells like fuel but im not sure. After about a min or two it goes away and i dont see it again until after it sits for 5 or 6 hours..Any ideas would be nice
is it possible its just a rich tune?\thanks guys
Old Apr 23, 2009 | 08:58 AM
BlackScreaminMachine's Avatar
Internet Mechanic
How old is the motor, (miles), did you do valve seals when you did the cam??
Assuming the smoke comes out the tail pipe and not the engine bay??
Old Apr 23, 2009 | 09:06 AM
RED94Z28's Avatar
yes i did valve seals engine has 97000 miles yes it is out of the tail pipes
Old Apr 23, 2009 | 10:16 AM
Internet Mechanic
Probably rings or blow by. I had a VERY rich PCMforless mail order tune that I had further richened when I though the A/F on the dyno was ultra lean. I never had smoke come out. The bumper wasnt sooty, but def had fuel wash down the cyl walls.
You maybe getting blow by the rings. Oil is not always blue.
Do a leak down test.
Old Apr 23, 2009 | 10:41 AM
Purple95Z28's Avatar
I doubt that. I broke the knock sensor once on my friend's 95, and it would go into a failsafe mode where it ran really rich, and it would blow a lot of black smoke because it was running so rich.
Old Apr 23, 2009 | 10:47 AM
RED94Z28's Avatar
i have a lt4 knock module that i havent put in yet ill try to put that in this weekend.
If it was rings wouldnt it do it all the time and not just when its cold?
Old Apr 23, 2009 | 10:58 AM
Wesmanw02's Avatar
Sounds like you have a fuel issue, possibly a leaking fuel injector or a leaking fuel pressure regulator. Either will cause the symptoms you are describing.
Your tune would have to be extremely bad and very rich to cause black smoke, but it is still possible.
Its not likely that its oil, burning oil creates blue smoke. Fuel burns brown/black.
Old Apr 23, 2009 | 11:12 AM
Internet Mechanic
Like said, the motor has miles, its good matience to do. Not all oil/fuel mix is blue some can be brownish. Also too much fuel can lift the rings and mess them up.
Do a Fuel pressure test, and also send the injectors out to get check and cleaned.
What I could say is the car may just have alot of carbon. Maybe a good seafoam treatment. That can work wonders.
With the car hitting 100k its stuff like that you may to need to start doing.
