Disappointed after modifications!
You could improve your ETs and overall HP output by using an appropriately sized cam.
B) By shifting it at 6500, you're running a significant risk of spinning a bearing.
I'm not telling you not to do it, but I want people who read this thread to understand that it's playing with fire.
Start saving for your rebuild and new rotating assembly now.
At this point it ould be less expensive to do a cam swap that will work well with the compression you have. If it still does not run then i would think strongly about sending your current heads out to one of the very well trusted gurus to see if they can be salvaged...
Guys, please, resist the temptation of throwing in an "x" when posting your numbers. That is, unless you don't care about the accuracy of the responses.
Are we talking 249 @ .050 or 240? Is the LSA 100 or 109? BIG differences!
Absence of torque tells me too much duration; cam's about 2-1/2 - 3 sizes too big for the CID and desired RPM range.
Remember HP is not measured, it's only calculated. It's TORQUE and RPM and the mathematical constant (5252) that determines HP.
The most common mistake made in camshaft selection is choosing one with too much duration. Check the Chevy High-Performance mag, March, 2008 issue to read all about it from interviews with the cam gurus from Lunati, CompCams and Crane.
Jake
West Point ROCKS!
Jake
West Point ROCKS!
