A/C Delete Question
Old Apr 29, 2009 | 01:23 PM
ss.slp.ls1's Avatar
Originally Posted by litch2004
I pulled mine because of the visual sore of seeing that part cut out of mine inside the engine bay. It really isn't that hard like everyone thinks, but it def helps out to have a second set of hands in there when trying to get the drivers side out. Mine is a trans am so I'm not to sure about your dash. But in my opinion it is well worth taking out the whole thing and installing the delete plate from the inside. And also I bought my a/c delete plate from Alvin at pcmforless. It is cheaper than the BMR one and it is of nice quality. They don't have them on the website so you just have to call if you want to go that route
How much was it?
Old Apr 29, 2009 | 01:28 PM
ss.slp.ls1's Avatar
if i remember right it was around 55. I might be wrong but like i said alvin could tell you for sure. He cut them for himself and went ahead and made extras. They are lazer cut aluminum. Fit up and lined up perfect on mine.
Nice, how long did the whole procedure take? Estimate of weight of the components removed?
Old Apr 29, 2009 | 01:30 PM
litch2004's Avatar
http://www.pcmforless.com/images/pro...s/fwdelete.JPG
This is made out of either 18 or 20 gauge 6061 aluminum
this is the rendering he sent me and he sold it to me for 50 plus shipping.
This is his number 704-307-4227
Old Apr 29, 2009 | 01:35 PM
BassProCamaro97's Avatar
I went to a local welding shop and got a 20" X 30" sheet of aluminum and cut my own this weekend. It cost me all of 10 bucks and 1 hour of cutting with a wheel.
Just throwing another option out there.
~Jim~
Old Apr 29, 2009 | 01:36 PM
litch2004's Avatar
I had mine pulled in about an hour and a half (not including reinstall of dash) i put the dash back in a few days later which took me maybe 45 minutes now knowing where all the bolts were and what it took to remove it. I also trimmed all unneeded wires; such as an old alarm that was no longer used, old audio system wires, all a/c related wires(minus rear defrost)and then retaped the wires back to the clips and clipped them back into the dash bracket. it removed roughly 30lbs i would guess. i might be wrong though i havent actually weighted it. That is also including the heater core plugged and full of old water.
Old Apr 29, 2009 | 02:10 PM
za355tx's Avatar
It's like a weight lifted off your shoulder when you pull out all the stuff from under the dash. It makes me feel good knowing all the useless junk (to me that it) is gone. The whole HVAC system weighs like 35lbs. Plus getting that engine bay cleaned up is a thing of beauty.
Old Apr 29, 2009 | 02:26 PM
litch2004's Avatar
Originally Posted by za355tx
it's like a weight lifted off your shoulder when you pull out all the stuff from under the dash. It makes me feel good knowing all the useless junk (to me that it) is gone. The whole hvac system weighs like 35lbs. Plus getting that engine bay cleaned up is a thing of beauty.
^ + 1
Old Apr 29, 2009 | 03:24 PM
bdsbirdman's Avatar
^ + 1
+2
it took me about 4 hours to pull the whole hvac out including the dash out and back in. I did have the advantage of pulling these dashes out a few times before but it really isnt that bad if you just take your time and keep track all of your little 7mm scews (they're are a ton of them) iirc
