Pulled DTC codes low TPS sensor
Old Apr 29, 2009 | 06:54 PM
Raven97's Avatar
Default Pulled DTC codes low TPS sensor
Hey guys. I just scanned the DTC codes for my car and I got a code for low TPS sensor voltage, I checked the wires and it was plugged in and the connector looked good, so I unplugged it to see if it mad ANY difference and nothing, how bad is it for the motor to run without it, I am having some knock and the car is pulling timing. (still needs to be tuned after rebuild) I am going to be learning how to tune it myself but I need to get this fixed before I can start.
Could it be pulling timing because of something related to the TPS sensor?
Also I have a code for the A/C evaporator sensor circuit. Where is this sensor located so I can check/replace it? also where can I find the correct Shrader valve for the low pressure A/C port?
Old Apr 29, 2009 | 07:05 PM
shbox's Avatar
I don't see how the engine will run right at all without the TPS working.
Old Apr 29, 2009 | 07:31 PM
Raven97's Avatar
Thats what I was thinking but it seems to run really strong from the seat-o-the-pants meter, I thinkI am just going to go out and get a new sensor and see how it does.
any Idea about the Evap sensor circuit?
Old Apr 30, 2009 | 09:20 AM
Ponch95's Avatar
Your Evap sensor and your MAP sensor are ran off the same circuit as your TBPS Sensor. Once you change your TBPS it should go away along with your Evap code.
Old Apr 30, 2009 | 10:18 AM
Raven97's Avatar
Not the Fuel Evap system the A/C evaporator sensor circuit OBD1 code 71, I sill cant fugure this one out AFAIN the only sensors are the one pressure sensor by the low side fill port and the plug on the compressor.??? I'm stumped
