Stroker ????????
Old Apr 30, 2009 | 12:36 AM
1fast432's Avatar
Default Stroker ????????
How much clearancing to block did you have to do to go 3.75 crank with 5.7 rods.Any major snafus putting it together? THANKS JB
Old Apr 30, 2009 | 09:10 AM
James Montigny's Avatar
Depends on the rods and rod bolts you select.
My Eagle 6" forged h-beam set and L19s required quite a bit of clearancing ... so much
that we had to weld the block to reseal the water jacket several times.
I eventually just half-filled the block for piece of mind.
With some kits, I've been told that little to no clearancing is required.
Old Apr 30, 2009 | 09:13 AM
z28rob18's Avatar
my block didnt have too much clearancing with the eagle 6" h beam rods. just some shaving on the rod bolts and some little notches in the block
Old Apr 30, 2009 | 11:40 AM
ss.slp.ls1's Avatar
Are you assembling your bottom end or are you taking it to a competent machine shop?
