gear drive timing setup for LT1's?
Old 04-29-2009, 11:05 PM
chevy2808's Avatar
Default gear drive timing setup for LT1's?
is there a gear drive for LT1"s to replace the timing belt setup? pic below...ive been looking but i havent found any for the LT1. thanks
Attached Thumbnails gear drive timing setup for LT1's?-geardrive-733x604.jpg
Old 04-29-2009, 11:21 PM
96lt1m6's Avatar
Lt1s do not come with timing belts..geardrives suck power use the OEM set up
Old 04-29-2009, 11:52 PM
chevy2808's Avatar
what do they come with? i should know this by now...
Old 04-30-2009, 12:06 AM
Bad_tx_Z28's Avatar
just a regular timing chain. why do you want a gear drive?
Old 04-30-2009, 12:08 AM
ONEBAD383STROKER's Avatar
What he said.
Old 04-30-2009, 12:12 AM
goldmecham's Avatar
he prob wants the gear whine so he thinks he has a blower under the hood.
Old 04-30-2009, 12:15 AM
Gear Drive = No Good
Old 04-30-2009, 07:00 AM
shbox's Avatar
If you are not running a knock sensor, it's ok. Otherwise, it will drive the knock sensor nuts from the noise.
Old 04-30-2009, 11:44 AM
ss.slp.ls1's Avatar
+2...don't waste your money on a gear drive.
If you have durability issues, get a double roller timing set and run an EWP.
Old 04-30-2009, 12:10 PM
lt170chevelle's Avatar
Yeah from what ive heard the gear drives do use more power up compared to a timing chain.
Old 04-30-2009, 12:46 PM
Bad_tx_Z28's Avatar
yup, no point in wanting something that eats up power. Just get a double roller from GM and you will be fine. If your wanting the whine of a supercharger under your hood, then...get one!
Old 04-30-2009, 12:48 PM
96lt1m6's Avatar
if you notice the old school blower guys use gear-drive units so they have NO WORRIES with timing chain slack/stretch which will kill a blower motor. they can sacrifice the power loss for the actual power gain..
there is nothing wrong with buying a NEW factory timing set up you have 3 choices from GM
stock Lt1
Lt4
Lt4HD
Old 04-30-2009, 01:00 PM
Bad_tx_Z28's Avatar
^^ yeah a friend of mine ran that kind of setup on his 69 nova. Talk about sounding sick.
Quick Reply: gear drive timing setup for LT1's?
