Why no 7 second LT1 yet?
Old Apr 30, 2009 | 06:39 PM
ss.slp.ls1's Avatar
Originally Posted by joelster
When/IF Dart comes out with that new block, you will see several cars in the 7's. 50 extra cubes plus a ton of added strength = guys being able to push more boost without fear of grenading a factory block to pieces.
Imagine building a 454 LT1.
Old Apr 30, 2009 | 07:11 PM
James Montigny's Avatar
Then trying to find heads that will feed it without choking ...
Old Apr 30, 2009 | 07:26 PM
ss.slp.ls1's Avatar
I thought a pair of ported, newer style TFS heads would do the trick?
Top it off with a single plane and a 4-hole.
Large solid roller.
LT headers dumped
Stand alone, crank trigger, rear mounted distributor...
Forged bottom end.
7500 rpm
Old Apr 30, 2009 | 07:37 PM
Elliott's94Z's Avatar
Should I be one of the first to do it? It's not too late!
Old Apr 30, 2009 | 07:41 PM
AChotrod's Avatar
Get to it son!!!
Old Apr 30, 2009 | 07:48 PM
Ok my new goals: 454 LT and then go do a back flip at the local track and hope I land it
Old Apr 30, 2009 | 07:59 PM
LOL
Old Apr 30, 2009 | 11:45 PM
Puck's Avatar
GT1 backflip off the line f-t-w.
Old Apr 30, 2009 | 11:53 PM
LMAO not what I had in mind..I'd like to do it from the dig and land it then to finish the 1/4
Old Apr 30, 2009 | 11:55 PM
94_formula_lt1's Avatar
a few guys here in ky run in the 7's with a lt, but thats in the 8th lol,
Old May 1, 2009 | 03:19 AM
Bowtie Boy's Avatar
Originally Posted by PNYKLR-TA
So do it then guy!
Maybe I already am...
Old May 1, 2009 | 05:38 AM
  #32
FASTFATBOY's Avatar
Rick Intrau ran 8.07 with a single turbo combo that wasnt really sorted, he did it in the middle of summer. Stock Suspension and a 10 inch tire. With some more time and cooler air it would have EASILY ran in the 7's.
Big Purple on here has a twin turbo LT1 that runs DEEP in the 8's.
There is also a guy on here that runs a 10 inch tire stock suspension nitrous combo up in Denver, runs mid 8's I think in that altitude. At sea level would run 7's. Its white with orange stripes. The build was documented on the board here.
Old May 1, 2009 | 08:55 AM
  #33
Puck's Avatar
The carb'd nitrous LT1 blew that combo before he could run it in good air Would have been another surely in the 7's.
Old May 1, 2009 | 11:37 AM
  #34
BizZzatch350's Avatar
Moderator
He made that pass, took the car back to the pits to up the boost but the motor had a spun a bearing. Though his car is done, I think Chris will take his record back of having the fastest LT1
Old May 1, 2009 | 12:24 PM
  #35
CamaroRacing12's Avatar
i would like to see Big rick get her back together and be the first into the 7's
Old May 1, 2009 | 12:49 PM
  #36
Puck's Avatar
Chris, if you are reading this and are the first in the 7s would you change your name to "Z7's"?
Lots of competition but my money is on you bro!
Old May 3, 2009 | 01:29 AM
  #37
LT1's Avatar
LT1
Awesome, lot of good info on this post. Looks like there's couple LT1's about to be in the 7's. Would be nice to see once they officially run 7's.
Old May 6, 2009 | 02:57 PM
  #38
stroked30th's Avatar
From the dead
We only went 9.doh's in a half season. If things work well financially this year we'll have our 8 sec pass up here in Denver; 7200+ DA
Motor is back together, dealing with some ignition issues currently. And we'll be back out on a 275 radial
Old May 6, 2009 | 03:49 PM
  #39
Puck's Avatar
Originally Posted by stroked30th
From the dead
You need to bring her down here for some nice sea level runs.
Old May 6, 2009 | 03:51 PM
  #40
FASTFATBOY's Avatar
As a rule isnt every 1000 ft of altitude a tenth?
