Trans problem?
Old May 5, 2009 | 07:04 PM
scott937's Avatar
Default Trans problem?
The car will daily drive fine but whenever i punch it it will not shift outta the gear im in. A friend of mine told me to change the TPS sensor and i did and the problem is still there. The trans is stock wit only about 3,000 miles on it. Any suggestions? Thanks
Old May 5, 2009 | 07:09 PM
ss.slp.ls1's Avatar
Year might change things some. Any mods...stock stall, stock TB?
Did you check your TPS voltage to see what it shows with the TB blade closed and WOT?
Old May 5, 2009 | 07:22 PM
scott937's Avatar
its a 95 with full exhaust and a small cam, stock stall and TB. I didnt check the TPS voltage but im gonna try that, Anything else it could be? Thanks again
