Who has the fastest car with a gm lt4 hotcam?
#41
Performance:
-355 LT1 w/LT4 Hotcam, stock heads, and 1.6RRs
-Racetronics 32# injectors, 52MM TB w/ airfoil, K&N CAI
-EWP, Underdrive pulleys, MSD Coil, Taylor 8mm wires
-Pacesetter LTs, Custom 3'' exhaust w/E Cut-out and Dynomax Ultra-Flo
-Tune from James Henson
-Engine has 52,000 miles since being rebuilt
-Built by 6-speed inc. 4a package transmission w/ SPEC stage 2 clutch:
-New OE Hyd Slave and master cyl.
-Pro 5.0 shifter
With all that im putting down 346
![](http://www.fquick.com/images/vehicles/extended/D_27340.jpg)
There is dyno sheet.
-Pro 5.0 shifter
Guys I had a hot cam before also and liked it at the time, now I have a real cam and love it.
Broken valve springs are from miss matched parts, like useing the hot cam sprngs with 847 or custom cam.
#42
I have a 6speed hotcam only car I ran it few wednesdays ago.I had 3 passes that night and I ran 12.6@112 with a crappy 2.0 60ft time both times.And for the third pass well I have a 383 on the way now.I loved the hotcam and I would deff recomand it.
#43
I don't know of anyone that made that much with a HOT cam and heads. I was running stock heads and went 12.4 back in '99. My parent's have the HOT cam with LT4 intake and heads in both Comp TA's. He did 375rwhp, also in '99. His car ran 12.2 back then and Mom's ran 12.5, M6 and A4 respectively.
I might throw mine on a dyno one of these days to see what its at now. But I know mine won't throw down some crazy numbers. Probably around 330-340rwhp.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#44
That's me actually. But I don't expect anyone here will believe it. No one did years ago when I acheived it. But I wasn't the only one. A few others got 400RWhp on the HOT cam also, like Brent Franker.
Pyro, yes some AI heads will help immensely. When I installed the ported heads I gained 40 rwhp, but that was with milling them .035 and using the LT-1 Impala gasket for another point compression increase. Btw, they are from Gallant Technical Performance(GTP). All us oldheads bought them back in the 90's because they were the hottest thing out there. But that only got me to 365 RWhp. After that I continued tweaking parts(like 58mm TB, EWP, ported intake, etc.) and tuning until I got the 400.
With patience, it is doable. Cripes, I put in the HOT cam in 1998 and the heads on in 1999 and the engine hasn't been apart since then.
It is definitely possible with the AI, they are very strong performers.
Exactly!
#53
I have a hot cam car without a single bolt on aside from my gmmg. Love it. With nothing else done to the car I ran a friend in a 99 T/A with the 3.23 rear gear (all stock)from 50mph-135mph...I had about half a car (or a little less actually)on him the whole way. And I know we've all heard it a thousand times...."You had to put a cam in it just to keep up". Well when were sitting in the parking lot mine sounds better and gets more compliments, who cares! I know for a fact he put down 302rwhp about 2 years ago when he put the car on the dyno. Either way, its not the best, its not the worst, but I can drive it every single day and it still puts a smile on my face every time I turn the key. Personally, I could care less what it puts down so long as I still enjoy it! Haha, to each his own and that's my two cents. Also I put mine on the dyno before I did anything to it and I put down 224rwhp and 251rwtq. Curious to know what it would do now.
#59
1 Post
Ill put some AI 200's on the car with the hotcam and see what it puts down. If I'm not happy I can always upgrade the cam later When money allows
