Rocker arm question
Old May 11, 2009 | 12:33 AM
GMRL's Avatar
Default Rocker arm question
Do Comp Pro Mag rockers come with poly locks included?
Part# 1305-16
Thanks
Old May 11, 2009 | 07:02 AM
shbox's Avatar
Yes, Pro Mags come with the poly locks.
Old May 11, 2009 | 09:43 AM
litch2004's Avatar
yes they come with them. My set that i got in last week came with them
Old May 11, 2009 | 10:15 AM
96lt1m6's Avatar
I have never seen a set of roller rockers NOT come with poly-locks..
Old May 11, 2009 | 11:01 AM
litch2004's Avatar
Default straight off the website
Procomp Stainless Rocker Arms
Procomp Stainless Steel Roller Rockers are manufactured from 21M4 high grade stainless steel. They feature greater strength and durability and are capable of withstanding valve spring loads over 750+ PSI. Each kit comes complete with polylocks
Old May 12, 2009 | 11:56 AM
GMRL's Avatar
Great! Thanks for the info. I broke a rocker stud(comp) on #5 intake and bent both pushrods on that cylinder so Im upgrading the whole valvetrain to 7/16 hardware. Hopefully nothing else is damaged.
I got
ARP studs
Pro Mags
Trick flow guideplates
Trick flow pushrods
and ARP polylocks, but I can send those back now.
Thanks for input.
Old May 12, 2009 | 12:03 PM
ss.slp.ls1's Avatar
I got
ARP studs
Pro Mags
Trick flow pushrods
Thanks for input.
^^^ That's basically what I have in my car.
Old May 12, 2009 | 03:07 PM
litch2004's Avatar
I got
ARP studs
Pro Mags
Trick flow pushrods
Thanks for input.
That sucks man. That is what i am putting in my heads right now. You just will not need the ARP polylocks since the rr already come with them.
Old May 13, 2009 | 04:06 PM
GMRL's Avatar
Got some pics today of the damage. Exhaust rocker stud on #5 broke. The cylinder pressure in that cylinder became too high since the exhaust wasnt getting out,the pushrod on the intake side and bent.
However I think the root cause is that the poly lock wasnt catching enough treads to hold it down properly. Also the poly locks I was using were a bit too wide for the rocker causing them to rub. Also the top of the poly lock was hitting the rocker body. All my fault I guess I should of checked it better when I assembled it. It ran fine for about 8 months though, I had installed 918 springs, comp studs and poly locks.
Old May 13, 2009 | 05:10 PM
ss.slp.ls1's Avatar
Nice new pieces.
Old May 13, 2009 | 06:04 PM
litch2004's Avatar
i have the same pieces minus the trick-flow push rods. I still have to bolt everything up and measure them out.
Old May 13, 2009 | 06:10 PM
Badazz 97 TA's Avatar
Originally Posted by ss.slp.ls1
Nice new pieces.
Do you seriously have to quote every damn picture in every thread you go to. damn
Old Jul 1, 2009 | 04:29 PM
GMRL's Avatar
Well, I got it all together a few weeks ago and have put about 1k miles on it since. It runs great, and most of all I love how quiet the valvetrain is now, sounds stock.
Those trick flow guide plates fit perfect, I only had a bit of trouble lining up #1 and #2. After everything was tightened up I let it run with the valve covers off till it warmed up. Then the pushrods on those cylinders started squealing from rubbing against the guide plates. I repositioned them, and its run great since.
