Advanced Induction Heads and Cam 383 New Setup
#88
That stove my cousins got ran a 12.6 @ 110 Friday night
he was doing bracket racing for import wars Sat. and decided to put down 13.2
he broke out with a 12.7
i dont know if he knew what bracket racing meant???
#89
Well the fuel pump and ignition system is in and its finally running again! The ignition project took a bit longer than I expected. If anybody is running ignitions similar to this let me know and I will show you the easiest way to install the crank trigger. Also there is a wiring error in MSD/XFI's schematic when hooking up a crank trigger to the XFI. If anybody needs to know just let me know and I'll show you the issues.
Track friday, the rain has finally stopped!!!!!!!!!!!!!!!
#97
Went up to NED friday night and ran O.K. I only got in three passes but they were decent for a traction challenged friday night with mufflers and a tune that went bad. The car went 10.88 @ 127, 10.83 @ 127 and 10.81 at 128. The only issue now is that the tune went off big time. My old 255lph pump would loose about 7 PSI from idle to WOT at 7 and 8K rpm but this new A1000 doesn't move from 45PSI. So between the mufflers and the extra fuel pressure my AFR went down to 11.9-12.0 from 3K to 6500 and then it fell to 11.0 from 6500 to 8000 which is where this motor makes its power. I got a new set of plugs going in it tonight and this week its going back to the dyno for another tuning session. Planning a track rental next week on wedensday I think. I'll put up the video of the 10.81 @ 128 pass I forgot to hit the record button on the other two passes oops...STAY TUNED MID 130'S COMMING SOON!!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#100
Yea it was packed plus I got a little distracted by that girl in the Z lol and Congrats on the KOTH win. I'll see if we can get it to be LT1 on LT1 in a couple of weeks. I'm gonna try to rent the track next WED if ur interested. I'm going to the dyno tomorrow and I'm gonna do some street "testing" this week.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
