What Kind Of Fuel Pump
http://www.racetronix.com/RX-FLT1-FPKG-2.html
Does the Walbro pump fit down into that white factory housing, or what they're referring to as the fill bucket? I'm assuming this kit works with the factory sending unit?
I think the pump I put in a few years ago might be shot, so I'm exploring options. I also need a new sending unit. My fuel gauge doesn't work, which kind of bites. The sending units are freakin' expensive.
Also, do NOT cut too deep or else you risk nicking the fuel lines. A small Dremel cut-off wheel is what I used.
I keep these kits in stock.
