Question!!!!!!!!
Old May 14, 2009 | 03:07 PM
shaq_2500's Avatar
Default Question!!!!!!!!
Does anybody have a problem with there car idleing. i have an 396 lt1 and when I started the car it idles rough and sometimes goes died. Just trying to see if anybody else has had this problem and what was the cause.
Old May 14, 2009 | 06:08 PM
shaq_2500's Avatar
anybody
Old May 14, 2009 | 06:16 PM
93blacktransam's Avatar
my ls1 does sometimes after the cam my tuner from boost performance said always to let it warm up untill it at least to the first mark on the temp...bout 5 min ....he said it will always idle rough till its warm
Old May 14, 2009 | 06:25 PM
shbox's Avatar
There could be lots of things involved. Observing scanner readings would go a long way in guiding you.
Old May 14, 2009 | 07:08 PM
ss.slp.ls1's Avatar
2908752759 things could be the cause.
Mods?
Tuned?
Need a lot more information.
As Shbox mentioned, a data logging scanner that reads real time data would be a great tool to use.
Old May 14, 2009 | 07:24 PM
96capricemgr's Avatar
Can a guess an aftermarket TB with the IAC bypass not done????
I suspect if you had a scan tool you would see the IAC maxxed out.
Could be mechanical issues or a bad tune too.
Old May 16, 2009 | 12:51 PM
shaq_2500's Avatar
thanks
