back fire through intake
Old May 14, 2009 | 07:35 PM
ElkySS's Avatar
Default back fire through intake
iv been trying to solve this problem for god knows how long. at first i thought it was just i miss, then i listened real close and found out its actually a backfire through the intake. only under load, at high rpm and its intermittent. it also changes. sometimes its not there, sometimes its barley noticeable, othertimes its so bad i think its gonna give me whiplash. anyone have any itdeas, nothing i do seems to change it at all.
new parts: opti, coil, plugs, icm, lifters, injectors, fuel pressure regulator, walbro 255 w/ hotwire kit.
it was dyno tuned with a bed opti on it and im thinking thats the cause but i dont wanna drop more money on a retune for them to tell me thats not it.
Old May 15, 2009 | 08:01 AM
ElkySS's Avatar
bump..
Old May 15, 2009 | 09:43 AM
96SCTA's Avatar
Was it doing this after you got it back from the dyno tune or did it start shortly after? You listed all the new parts are these all new after the problem started or are they recently installed then this problem occured. Johny five needs more input
Old May 15, 2009 | 06:48 PM
ElkySS's Avatar
injectors, ls7 lifters, and acdelco fpr wer installed with the cam, everything else was after.
it was barely running before the dyno. i thought the cam was too big to run on the stock tune when we got it tuned but it turned out to be an opti
Old May 17, 2009 | 02:04 AM
ElkySS's Avatar
bump..
Old May 17, 2009 | 02:18 AM
hitmanws6's Avatar
longshot but the plugs could be fouled
Old May 17, 2009 | 06:57 AM
Anthony0908's Avatar
make sure there are no vac leaks any were . Unmetered air in the engine will cause this. Do you have a SES?
Old May 17, 2009 | 08:23 AM
Blown427conv's Avatar
What about a weak or broken valve spring or sticking (slightly open) intake valve?
Old May 17, 2009 | 12:10 PM
ElkySS's Avatar
i put in new springs, rockers, push rods when the cam went in and have been out since to fix a head gasket. and it was doing it before the head gasket. no ses. its kinda hard for obd1 to pop a code lol
Old May 17, 2009 | 12:12 PM
ElkySS's Avatar
my maf is descreend. (i bought it like that) could this or a bad maf cause this?
Old May 17, 2009 | 12:21 PM
Patriotpa's Avatar
Yes. With the screen removed the MAF is getting turbulent air that will skew its readings. I'd swap out the MAF. OEM and Granatelli Performance are about the same price.
Old May 17, 2009 | 12:28 PM
ElkySS's Avatar
ill borrow one from my buddy and see what happens
Old May 17, 2009 | 02:20 PM
A dirty MAF will do that too. Cleaned a few (carefully) and fixed some stumbling and backfiring problems.
Old May 17, 2009 | 03:12 PM
ElkySS's Avatar
unplugged the maf and went for a drive, no change (except the ses light)
Old May 17, 2009 | 03:15 PM
ElkySS's Avatar
well the plate on top of the tb is leaking. im thinking that MIGHT have something to do with it if it pulls a vacuum there. how do you guys get that thing to seal? the rubber expands when it gets oil on it. do you just use rtv or regular gasket material or what?
Old May 17, 2009 | 03:16 PM
I dont think your car should run it it unplugged? lol?
If there is no gasket to it i dought it draws air in.
Old May 17, 2009 | 05:14 PM
creepingdeath94's Avatar
If you unplugged your MAF and there was no difference in driveability, I think something is wrong there. The MAF is important enough that it should run poorly without it hooked up and if it is the same, I think your problem lies there somewhere.
Old May 17, 2009 | 05:25 PM
ElkySS's Avatar
well lt1s (maybe ls1 too) have a redundant system. when you unplug the maf it runs off of speed density
Old May 18, 2009 | 02:19 AM
robsquikz28's Avatar
dude it will run like **** if not even start
Old May 18, 2009 | 02:26 AM
hitmanws6's Avatar
i forget the name but its a black liquid in a little tube. kragen sells it for a few bucks
