header rubbing on steering knuckle help
Old May 27, 2009 | 03:08 PM
djjab57's Avatar
Jet Hots are what i have, they come apart and go around the steering shaft
Old May 27, 2009 | 03:10 PM
djjab57's Avatar
and if im not mistaken Hookers do the same thing
Old May 27, 2009 | 04:45 PM
pillarpod's Avatar
I bought those headers and the same thing happened to me. ....but all is good now
Old May 29, 2009 | 03:16 PM
Al 96 Ram Air T/A's Avatar
Here's a shot at the shaft to header clearance after I moved the column over and replaced the rag joint.
Not a huge difference, but at least a 1/4" clearance now.
Old May 29, 2009 | 03:31 PM
1993 z28 f1's Avatar
Hey:
You can also change your whole rack to the newer 00-02 ws6/f41 rack
with steering shaft. no welding just alot of time getting all lined back up, so the wheel still in the center.
You can find them as cheap as a rag eliminator and new ujoint and you would have a newer rack and maybe better ratio.
Just another option.
Dub
When In Doubt Do Without
Old May 29, 2009 | 04:17 PM
Hardtop94's Avatar
yes hookers have the first primary that slides off for installing around the steering, easy as pie
Old May 30, 2009 | 01:19 AM
ls1adamls1's Avatar
how hdumdumdum was it to move the colom over?
